tips?
tips?
Trying to replace my front shocks and struts. Only problem is the end link nuts just spin, they don't loosen or tighten, and the 4 strut bolts won't budge probably rusted in so they're soaking. Any tips to get these out?
Get some vise grips I think they are called and see if you can hold it in place. If that doesn't work then your more than likely going to have to cut them off for the endlinks atleast
Alright I'll try that thanks. Tried taking it off the sway bar because they need replaced too but I was in a rush and only tried with my 1/2" so I'll probably try that with my 3/8" as well
Yeah I bought moogs to put on. These are the originals though. 100k miles of rust and wear. Tried everything, even heating them up but they're too badly rusted I guess so first thing tomorrow I'm buying new blades for my reciprocating saw and cutting em out. Thanks guys
They're cut out. Cut them out at the sway bar because the nut won't move at all and they need replaced but they still won't so I guess it's either keep trying or drill em out lol. Gotta love pa winters.
Go get a jell rust remover, cover the bolt ends and give it a few then rinse off they should fall out better. WD40 isn't that good at eating rust, just preventing rust for a period of time.
Alright I'm going to have to go to napa anyways. These bolts are done due to corrosion and how hard I had to hammer em. Anyone know the part# because I can't seem to find em or would any number 120 bolt do?
True and usually at least for me more enjoyable. Have to redo the drivers side because according to my brother in law I put the top insulator in upside down and the bearings on top instead of under but that's a quick fix and rookie mistake. Thought that's how it came apart but oh well
CudaJoe
04-18-2016 11:39 AM
09SS7163
03-28-2016 12:44 PM
