Uneven ride height after lowering springs
Old 08-25-2016 | 07:58 PM
05ChevBaltSS's Avatar
Not sure where i went wrong?
So, I bought the SSC lowering springs from ZZP and a new set of KYB struts to go with them. So I installed the springs and struts everything went smooth. I drove the car for about 500 miles or so now and let the springs settle in before i started critiquing how level it was. The drivers side rear is higher than the other rear. And the passenger side front is higher than the other front. Its about a 1 finger gap difference, so almost a 1/2inch difference in wheel gap Why is this.? Ive been doing alot of research myself and cant find out why, ill be working on the car this weekend doing other things, anything to check while im working on it?
I dont really want to take them back off either but if i really have to i will.
Thanks in advance guys
Old 08-25-2016 | 09:23 PM
could be install error. The front springs have to be aligned correctly and the rear springs there is a isolator that can wear odd or not sit down correctly on the bump stop.
Old 08-25-2016 | 10:48 PM
Staged07SS's Avatar
Administrator
Administrator
This.
The front springs need to align in the spring perch properly.
Also the strut mounts need to be aligned correctly as well.
Old 08-29-2016 | 04:08 PM
I took the car into the shop and got underneath the car to take a look. The bump stops looked like they were set properly. Also the springs were seated the same on each side and looked identical front and rear. Im just really lost and not sure why this is happening, really starting to bother me. Ive been told im supposed to get an alignment after lowering your car but i dont think that has anything to do with the ride height, only the camber angle...
Old 08-29-2016 | 08:22 PM
cluelessk's Avatar
Well if the installation checks out fine it's probably a manufacturing issue......
Old 08-30-2016 | 09:22 AM
royce777's Avatar
I never had a cobalt that sat with the same height on each side. Some closer than others but none the exact same.
Old 08-30-2016 | 09:31 AM
Staged07SS's Avatar
Administrator
Administrator
My car sat perfectly level...
Old 08-30-2016 | 09:47 AM
royce777's Avatar
my g5 was on pedders, bc coils, and bags and never sat even on any of them.
Old 08-30-2016 | 01:48 PM
cluelessk's Avatar
If you're on coils you should be able to get it sitting even.
Old 08-30-2016 | 01:58 PM
royce777's Avatar
I understand that. But if I had everything measured and adjusted the same on each side the car would sit uneven.
Old 08-31-2016 | 09:54 PM
no_ss's Avatar
Never had any problems with any suspension mods I've done on either of my cobalts that ive owned.
Surmousky
05-02-2016 02:22 PM
ShizahSS
03-27-2016 10:51 PM
Ricky Schell
03-18-2016 08:11 AM
tCSX
02-28-2005 03:16 PM
