What would I need to go from Fe3 to Fe5 front sway bar?
My 2005 Cobalt with fe3 which is base suspension needs a new sway bar in the front and I was wondering what parts would I need to replace it with a fe5 sway bar from an SS?
The dealer said:
Fe5 Link kits
Fe5 Bushings
Fe5 Brackets
Fe5 Control Arms
The only one I question is the fe5 control arms.
The dealer said:
Fe5 Link kits
Fe5 Bushings
Fe5 Brackets
Fe5 Control Arms
The dealer said:
Fe5 Link kits
Fe5 Bushings
Fe5 Brackets
Fe5 Control Arms
The dealer said:
Fe5 Link kits
Fe5 Bushings
Fe5 Brackets
Fe5 Control Arms
I am going to assume you mean you have a 2.4 with FE3 suspension. I suggest you keep the stock front bar. The larger FE5 bar will increase understeer. I suggest instead upgrading to a rear sway bar, particularly the Powell Street Bar. This will control some of the body leaning without creating horrendous understeer.
If you do go with a FE5 front bar, you do not need FE5 control arms.
I typed up a more detailed reply, but the site kicked me off before I could post it. This site can be frustrating.
To make is short, get a buddy to jack up your car and check the clamp down bushings and end links first. Also check for signs of a front end collision. (Sway bars don't just break.)
Check the sticky, Suspension and brake facts (FE1, FE3, FE5, J41, JM4, JL9) for part numbers etc.
I would like to add that the dealership costs more to buy the fe1 swaybars buying the fe5 is cheaper.
My dealership quoted me $248 for the fe1 swaybar.
And $120 for the fe5 swaybar.
Then they tried to make excuses on why it wont work such as control arms are different and I would have to buy them at $300 a piece.
DANRICKARD
10-01-2015 01:08 AM
