Whats the proper way of tightening rear axle beam?
Old 04-04-2016 | 09:54 PM
flip8419's Avatar
I'm asking because I had to loosen the rear axle beam bolts so I could install lowering springs.
Correct me if I'm wrong but is it, to tighten the bolts to 66 ft lbs while the car is on the ground? Right now those big rubber bushings squeak like a bitch!
Old 04-05-2016 | 12:11 AM
Grave's Avatar
Rubber bushings need to be tightened at ride height.
For future reference, just push down on the beam to remove the springs (with the shocks and brake line brackets disconnected, obviously).
Old 04-05-2016 | 11:19 AM
flip8419's Avatar
Oh we pushed and pulled, still didn't drop enough. Do you know the torque specs for that bolt?
MitchSS
04-20-2016 11:04 AM
mikeluis92
04-05-2016 08:58 AM
yellow_cobalt
04-03-2016 09:20 AM
Extremespeed
04-01-2016 01:08 AM
24ss06
03-30-2016 03:26 PM
Quick Reply: Whats the proper way of tightening rear axle beam?
