YYZ springs
Old 08-11-2015 | 08:46 PM
  #776
mh167002's Avatar
No, thank you John. I am also corresponding with Gloria on a hardcore bar and motor mounts. This may be too much awesomeness for me to handle all at once. Lol
Konis
YYZ's
Rotated mounts
Hardcore bar.
Should be a totally different animal.
Powell Race Parts (08-11-2015)
Old 08-11-2015 | 09:36 PM
  #777
Thats the set up i have and love it
Old 08-12-2015 | 09:28 AM
  #778
yellowsupercharged06's Avatar
anyone want to tell me where the white plastic disc goes on the Koni struts ?
I think it goes under the bump stop, but i didnt put it on there cuz it was really loose and i didnt want any rattles or anything flopping around. Is it necessary to have it on there ?
Old 08-12-2015 | 11:34 AM
  #779
I cant remember let me check to see where i put mine, but i havent had any problems wherever i placed it
Old 08-12-2015 | 12:10 PM
  #780
got these silencers from CED. There a plastic material and not rubber. They almost feel like there going to crack and dry out over time ... we shall see though.
Old 08-12-2015 | 12:23 PM
  #781
Staged07SS's Avatar
Administrator
Administrator
Tein silencers are a rubber/poly type material.
Have been holding up great.
Old 08-12-2015 | 12:42 PM
  #782
Old 08-12-2015 | 12:46 PM
  #783
Staged, thats what i thought these were going to be .. nope there plastic. They are also cut on the back side i would assume to help them bend easier, then there is a bead of glue along the inside to keep them from splitting more. I hope John tested these out in winter.
thanks Eddie ! thats where i thought they went but i kept mine out lol ... it wont make a difference.
Old 08-12-2015 | 01:05 PM
  #784
Yeah it probably wont lol but i put mine in either way. I didnt really see another place they could go
Old 08-12-2015 | 06:43 PM
  #785
Powell Race Parts's Avatar
I did not test the spiral wrap that hyperco supplied. It is used on Ford Performance springs for the same thing. Hyperco make those.
I am using a spray material, and Hyperco and myself are monitoring the situation as we see what solution works best. And we will see how it goes. The springs have a lifetime warranty if they break or loose rate. I really dont have much patience to go through the "what ifs".
I have only ever seen one damaged YYZ spring ; it was from a collosal endo roll over that wrote the car off; I offered to replace it free of charge just to have a look at it and test what forces it went through to bend the spring sideways, but the owner never took me up on the offer.
Old 08-12-2015 | 06:44 PM
  #786
Originally Posted by Snail_SS
I would use the bump stop isolator that Koni supply. Also, FE5 later (08 on?) bump stops are shorter than FE5 early and FE3.
Old 08-12-2015 | 07:32 PM
  #787
I would of send the spring, i need to get coil wrap tho since my springs are making noises
Old 08-12-2015 | 08:21 PM
  #788
you got the email addresses just supply the information and you shall receive.
Old 08-12-2015 | 08:24 PM
  #789
I would but i got mine from someone here so idk if it still counts for me
Old 08-12-2015 | 08:41 PM
  #790
Yeah same with me, got them new never installed from a memeber.
Got my silencers in today slaped them on and initial test results show it works.
Old 08-12-2015 | 09:13 PM
  #791
Yup mine where used but still work great ill order mine on friday from ced
Old 09-02-2015 | 03:11 PM
  #792
ROADKONE's Avatar
Anyone on FE5 YYZ Setup want to post pics of height?
Old 09-02-2015 | 03:19 PM
  #793
Fe5 and Konis won't be any different actually is the spring that makes the difference not the shock or strut
Old 09-02-2015 | 03:42 PM
  #794
google .......
Old 09-02-2015 | 03:44 PM
  #795
ROADKONE's Avatar
Ive searched google... For several different setups and its the same 15 cars that show up. Howeverr i think i found what im looking for.
Old 09-02-2015 | 03:46 PM
  #796
there all the same ! https://www.cobaltss.net/forums/susp...prings-287018/
(that took me 2 sec, btw)
Old 09-02-2015 | 04:16 PM
  #797
colodude18's Avatar
YYZ & Koni yellows: 2 fingers in the front, 3 fingers in the back.
<insert "that's what she said" joke here>
Old 09-02-2015 | 04:45 PM
  #798
Yup same gap i have on my springs well a tad less on the back but i might have bigger fingers who knows lol
Old 09-02-2015 | 04:56 PM
  #799
colodude18's Avatar
lol
Well my 3 fingers in the picture measure exactly 2.5 inches. Whip out your ruler!
Old 09-02-2015 | 04:59 PM
  #800
Lol we can leave it at that
Quick Reply: YYZ springs
