TNT Autosport TNT Autosport is a proud Supporting Vendor of CobaltSS.net
Garrett Turbo Kits now available!
Old 03-02-2007, 09:42 AM
TCarter's Avatar
if hes gutting the supercharger, and just gonna tap into it via the turbo...then the pressure sensor wouldnt matter since its before the supercharger.
even so, you can disable it with hptuners.
TCarter is offline
Old 03-02-2007, 05:43 PM
NJHK's Avatar
Originally Posted by TCarter
How come Mr. Adam doesnt get on aim anymore?
I'm rarely on AIM just cause I don't have the internet at home and at work I can't use AIM.
NJHK is offline
Old 03-02-2007, 06:42 PM
TCarter's Avatar
pfft, you used to be on aim at work all the time...everytime id talk to you, youd be at work.
TCarter is offline
Old 03-02-2007, 07:25 PM
NJHK's Avatar
I used the meebo program and that was when we weren't so busy. We've been kind of busy lately with CVS stores.
NJHK is offline
Old 03-02-2007, 07:39 PM
heatseeker's Avatar
I see you mentioned the 2.4, but will this kit work for it?
heatseeker is offline
Old 03-04-2007, 10:18 AM
TCarter's Avatar
I am going to say Yes. Although this kit is marketed for the 2.2, it will bolt up to the 2.4.
The difference between a 2.2 settup, and the 2.4 settup is nothing. the 2.4 just has more displacement.
The blocks are the same size, the layout/everything in the engine bay is identical.
TCarter is offline
Old 03-04-2007, 12:20 PM
I'm old school
Halfcent's Avatar
There are a number of people wanting to use this kit on either a 2.4 or an auto. It will work, but with the following differences;
On the 2.4, you will have to use HP Tuners. Not a big deal actually. In fact, you guys already have the necessary tuning tools that the 2.2 is still waiting for.
If you are putting in on an auto, there are two issues. First, if you read the installation instructions for the kit, it has you install the oil return in the cast-in dimple on the side of the engine block lower girdle. You can't do that with the auto because the transmission is in the way. You would have to install the return in the oil pan. Not a big deal since you have to remove the oil pan either way. It's easier actually, because you will have the oil pan off and can do the job on the bench.
Second, you need to be able to tune your transmission as well as your engine. Again, for the 2.4 guys, your set with HPT, because they support trans tuning as well.
Now I have a question. The kit is sold with the GT2860RS. I want the GT2871. Can you get the kits with a different turbo right from the start? Or do I have to buy it separately?
Halfcent is offline
Old 03-04-2007, 12:50 PM
Listerman's Avatar
i always love when halfcent makes a post. how much of a difference you think the gt2871rs would make?
Listerman is offline
Old 03-04-2007, 01:00 PM
I'm old school
Halfcent's Avatar
The GT2860RS can hold a 2-1 pressure ratio (15 psi boost) at 25 lbs/min. Good for anything up to 250 HP on this engine. The GT2871 can hold a ratio of 2.5 (22 psi boost) to 35 lbs/min. Good for up to 400 HP.
Garrett states the kit is designed to deliver just over 200 HP, so its probably set at around 7 psi. You can turn up the boost, but would need to tune it. This set up would make for a very fast spool time, so the car would have a peppy acceleration. If you turned up boost much past 15 psi however, you will run out of air at the top end. Still, you are efficient to around 250 HP, which is pretty damn good.
With the bigger turbo, you sacrifice a bit of that quick acceleration, but now you make a ton of power. It's really only necessary with a built engine that can handle it. I might very well start with the GT2860 and max it out first to see how the car handles before I swap up to the GT2871.
Halfcent is offline
Old 03-04-2007, 01:05 PM
Listerman's Avatar
so which do you think will spool quicker and which will last longer? or will it even me noticeable.
Old 03-04-2007, 01:09 PM
  #36
I'm old school
Halfcent's Avatar
They are same basic design, so they should both last the same. Durability really isn't an issue. They are ball bearing units with oil and water cooling. They should last forever.
Halfcent is offline
Old 03-04-2007, 01:13 PM
  #37
Listerman's Avatar
do you believe each will last til redline or fall short?
Old 03-04-2007, 01:36 PM
  #38
Cobalt5533's Avatar
halfcent, i notice you seem to have a very big interest in this kit, did you drop hahn or did hanh drop you ?
Cobalt5533 is offline
Old 03-04-2007, 02:38 PM
  #39
I'm old school
Halfcent's Avatar
Actually, neither. Hahn is probably going to retail the Garrett kit in leiu of selling their own. Its still up in the air pending the successful outcome of tuning from SCT. I don't even have any really solid plans yet. I will probably do a bit of hybriding. I want to use the Garrett manifold, turbo, downpipe and charge plumbing. I want the Hahn intercooler and Sheetmetal intake manifold, and Exhaust system. And then ofcourse a flash tuner from whoever gets one made first!
Halfcent is offline
Old 03-04-2007, 03:17 PM
  #40
Listerman's Avatar
whats your experience with internal wastegates? generally you see externals on high end builds but you seem satisfied with this setup from garrett
Old 03-04-2007, 04:10 PM
  #41
I'm old school
Halfcent's Avatar
The turbo really isn't big enough to warrant the need for an external gate. Internal gateing is a nice, compact option, fewer parts, and works great for our 4 cylinder applications. Plus the Garrett and Hahn designs are really simple.
Halfcent is offline
Old 06-13-2007, 12:02 PM
  #42
bc3tech's Avatar
and nobody asked how this thing tunes on a 2.2?
bc3tech is offline
Old 06-13-2007, 03:19 PM
  #43
I'm old school
Halfcent's Avatar
It was never advertised to have tuning, so why would we?
Halfcent is offline
Old 06-13-2007, 04:03 PM
  #44
bc3tech's Avatar
kinda pointless then *shrug*
bc3tech is offline
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
patooyee
10-15-2015 05:11 PM
maliki778
10-01-2015 07:39 PM
Quick Reply: Garrett Turbo Kits now available!
