GM Stage 2 - Maxed Inj in Winter?
With the cold air where I live during this time of the year, I think I am maxing out injectors on my GM stage 2 kit. The other day when ambient temps were in the teens there was an audiable change in the noise of the engine above 6400rpm. With the aeroforce I measured 16psi on the 3.07in pulley. Considering the AFR is in the mid to high 10s (Rich GM Tune) does this sound probable, I will be getting a tune soon hopefully.
A video is here: https://drive.google.com/file/d/0B4G...ew?usp=sharing
Forgive the honks, my buddy with a cobalt ss/sc wanted to run, hes stock so you cant see him in the vid. Lol
Very possible that it hit 100% IDC at 16psi on stage kit injectors, but since the A/F is so rich it won't matter. If it was tuned to a more sensible A/F it wouldn't be at 100% on normal stage 2 boost.
Yeah, im thinking its mostly because of the cold weather, because 16psi is high for a 3.07in pulley. I usually only hit about 14-14.5psi in the summer when the air is less dense. If i get a good tune on a 2.9in I will either switch back to gm pulley in the colder months or just remember to shift earlier.
I always make sure everything is warmed up before I ever run it fast in cold weather, usually won't do runs below freezing but my friend wanted to see the difference between stock and stage 2.
Hmmmm wonder where that saying comes from, great turbo/blower weather............ But yet around here anyone says anything about going wot in cold temps and everyone thinks the motor will go boom. Not seeing where it will go boom if the tune is correct and the engine is fully warmed up.
Hmmmm wonder where that saying comes from, great turbo/blower weather............ But yet around here anyone says anything about going wot in cold temps and everyone thinks the motor will go boom. Not seeing where it will go boom if the far is correct and the engine it fully warmed up.
Those stock timing adder tables based on iat like to add a lot of timing at the coldest temps. most people zero out these portions so that your not adding a bunch of timing in the cold, but it doesnt typically cause issues for those with a stock or gms2 tune because they run so rich.
After a bit of research though, it seems gm mafs actually can account for mass variations due to temp fluctuations and provide a real mass value instead of just flow as some of the older mafs tended to do. So i was wrong.
Im still a bit skeptical that it is always accurate though. Extreme hot and cold temps can really screw with electronic measuring devices.
keep in mind that our cars, like any other modern car, are designed to sell at any place in north america. they have the be set up so they can run in the desert in vegas and that same car can be driven up to northern canada and still run fine. gm had to be able to warranty the car no matter where it went. aside from california, the stock tunes are all the same regardless of location.
my point is, the pcm has to be able to compensate for hot and cold, high and low altitude. when tuned, sure, the tuner may not be able to access all the tables that help with temp related conditions, however it doesnt mean that they need tweaking, and that they arent still doing their job. however, like any tuned car, you should be keeping an eye on things all the time. im always watching for knock and keeping an eye on my afr. i find very little variance in afr between summer and winter. if anything, i find it actually tends to run a little richer below freezing, and that tells me the pcm is compensating for the colder air temps, like gm intended it to.
i typically dont beat on my car in the freezing cold though, cause where i am we tend to have black ice a lot. and what fun is beating on a car on snow tires?
That's about as cold as my car ever see's anyways, lol.
I can understand that if the car was tuned in the summertime and then the temps cool off. It seems like a winter tune and a summer tune is a good idea!
Already seeing this myself since I had wot set at 11.6-7 on the top end, and last night on the way home was hitting down into 11.2 just with it being 10 degrees warmer.
Edit
Yes.... lean out the AFR a bit.
You will get a little extra headroom with the injector pw with the leaner afr, as it won't be commanding so much fuel.
GMS2 was designed to run rich to cater to all sorts of different climates, elevations, locations, etc. Lean it out, watch for KR, and adjust accordingly.
What staged said. If you have access to hptuners, just disable cat over temp fueling corrections for pe, lean out the pe enrichment ratio to 11.5ish on the safe side, use a wideband to get your maf calibrated and watch for knock retard. If you get knock, either drop a degree of timing or so in the wot section of the table and make sure it has smooth transitions. Thats all i did on gms2.
Im not sure if cat overtemp is actually meant to prolong the life of a catalytic converter or not. My car was always catless when i disabled it
Staged07SS (01-27-2016)
Was alot warrmer today ~50'F and I hit about 95% at worst out of all my runs. Mostly about 90%.
Wideband AFR is still reading in the 10s either way so atleast no dangerous lean spikes, my STFT are decent (Below +/-5% on highway cruise) for a GM canned tune so my MAF calibration is surprisingly not horrible for never being tuned.
I will probably be going 60lbs Injectors and a 2.8in Pulley here in a little while and have it tuned in for 93 octane at 11.5:1 or so, looking for +20whp... we will see.
It definitely scares me how many people run 2.9s year round on GM Stage 2 Tune. I could see you getting by in above 70'F ambeint but definitely not when its cold, I am having trouble with the 3.07 lol.
As long as your Air Fuel stays good, I wouldn't get too excited about IDC going past 100%.
It's a calculated number.
I see mine go to 110% frequently on my turbo LS during a pass. AF stays rock solid.
