GM Stage 2 - Maxed Inj in Winter?
Old 02-02-2016 | 08:25 PM
blueLNFftw's Avatar
Originally Posted by xRedrumisBack
I don't however I am in touch with a local tuner thats going to get me setup on some 60lbers and a 2.8 here in a month or so.
Hope he is experienced with the Ecotec.
Old 02-03-2016 | 12:18 PM
xRedrumisBack's Avatar
Yeah he has done tons of cobalts in the past, if I am correct he owns a built cavy and a cobalt ss. My buddy has a TC cobalt tuned by him and it seems very stable.
Old 03-07-2016 | 01:55 AM
HP Tuners let me know I was indeed going over 100%, Have 60s and a 2.8 in there now. IDCs are much much better!
I ended up going to self tuning route, like to be able to make adjustments myself as needed. HP Tuners is great!
Heres a snapshot of my new setup during a quick pull.
Old 03-07-2016 | 11:36 PM
ItalianJoe1's Avatar
Only 7000 rpms? Don't need big injectors for that, would have be perfectly fine on the 42's and a 2.8.
Your car is breathing well though, the exhaust must be helping out nicely. 16psi on a 2.8 is a good thing.
Old 03-08-2016 | 01:34 AM
Just trying to keep IDCs down, redline is set to 7200 but i don't drive it that high.
Old 03-08-2016 | 01:35 AM
log looks nice. good work
Old 03-08-2016 | 10:29 PM
What's the fun in that? Turn that sucker up to 7400, helps with the long 1-2 shift at least.
Old 03-08-2016 | 10:45 PM
Iiiii wouldnt take a stock motor to 7400. Just my .02
Old 03-08-2016 | 10:47 PM
Did it for years.
Old 03-08-2016 | 11:01 PM
On stock head and cams I am sure power is dropping off over 7000, I rarely go from a stop (**** tires) so mostly 2nd gear pulls anyways.
If i ever WOT in 1st tires spin and it hits the rev limiter, going to put some good summer tires on the front when the weather permits though
Old 03-09-2016 | 08:18 AM
  #36
Staged07SS's Avatar
Administrator
Administrator
You need to ease into 1st.... It's very short and easy to bounce the limiter.
Ever watch you tube videos of kiddies showing off in these cars? You always hear them bouncing off the limiter and bogging when they hit 2nd.
Good tires will help traction though for sure.
Old 03-09-2016 | 07:33 PM
  #37
Yeah for sure, barely even get PE on 1st gear pulls because of easing into it, I may mess around with boost limiting as well and see how that goes.
Old 03-11-2016 | 12:29 PM
  #38
I used to run 40% boost in 1st until 6500, let it pick up a decent amount of speed before blowing through the limiter completely. On my setup with sticky tires, two hits against the limiter was just about perfect to be an full ground speed for a good 1-2 shift without bogging.
When I ran the nittos, I didn't need the limit, so I just kept a little hose in the car to cap off the solenoid for serious launches. Car felt dead with boost limited and real tires from a dig.
Bika
11-11-2014 11:00 AM
pykie
03-15-2014 11:00 PM
79TAKid
07-20-2012 01:05 PM
RedCobaltLs
01-07-2009 11:44 PM
hungryhip-ccp
02-08-2008 05:43 PM
