I think my car is making too much boost...please help!
Old 07-25-2018 | 03:39 PM
Chelsxo's Avatar
Originally Posted by Stealth-TC
Definitely ensure you are reverted back to a stock tune to get that out of the way...
Personally I would ensure all the lines are run correctly to both solenoids (One on the turbo and one on the intake manifold). Boost leak and Smoke test the IC system and VAC lines all when replacing the motor.
If the gauge is still reading 200 KPA (I wouldn't be hitting WOT for engine brake in PS), I would find someone local to you with HP tuners to log the car. HPTuners can read boost output and you can confirm if its the gauge acting up or something else.
Thanks for the info I will be passing all that onto ya mechanic!!
Old 07-26-2018 | 06:51 AM
63 Nova SS's Avatar
Which map sensors do you have? Do they have 2 little bolts holding them on or 1? Easiest one to see is on the intake manifold.
yellowcobaltsc
08-17-2018 12:12 PM
06CobaltssOrange
07-14-2009 06:49 PM
2k8turboSS
04-20-2009 12:02 PM
fastblackSS
09-07-2007 06:04 PM
TheYellowSS
05-09-2006 03:52 AM
