MAF fail high 0Hz causing limp mode
Old 02-21-2016 | 03:22 PM
xRedrumisBack's Avatar
Trying to setup my tune to dial in my VE tables and when I set the MAF fail high to 0Hz the car will go into Limp mode almost immediately after I start it, my dash also says "ERROR" after I flash. Any help would be appreciated, thanks!
Old 02-21-2016 | 03:51 PM
ItalianJoe1's Avatar
Why would you set it to zero? Set it to 13K or so
Old 02-21-2016 | 03:56 PM
Trying to fail the MAF to tune VE as stated in alot of tuning guides
Old 02-21-2016 | 04:15 PM
Could unplug it
Old 02-21-2016 | 04:30 PM
Could unplug it
Seemed to have worked. Have to throttle alittle on startup for the first 15s or it dies but then it runs fine . Thanks!
Old 02-23-2016 | 12:06 AM
Switched over to vcm suite 3.0 and redid the tunes and scanner and now it works. Haha not sure what changed but tuning is moving forward now.
joshcsepegi
02-21-2016 01:28 AM
Glenn Rodgers
02-18-2016 01:36 PM
Tomcat801
02-17-2016 03:47 PM
jcalvin1126
02-17-2016 02:02 PM
Ben Blonde Rupprecht
Tuning
01-25-2016 05:52 PM
Quick Reply: MAF fail high 0Hz causing limp mode
