Turbo Tech Racing Turbo Tech Racing is a proud Supporting Vendor
Engine dampner
Old 04-19-2006 | 08:36 PM
  #101
max_boost's Avatar
Originally Posted by djt81185
Installed in like 5 minutes. No more dash shaking wheel hop...just a faint hint. i had to move the heim joint in to fit b ut defin ately worth the money...doesnt feel like my car is gonna snap in half anymore. With the CA bushings there definately wont be any more hop...also no extra vibrations and no sunds going around corners...2 thumbs up 5 stars!
Dan
Awesome, can't wait to get mine installed. Won't be until Friday or Saturday though.
Old 04-19-2006 | 08:38 PM
  #102
maxpit's Avatar
Just got mine today. Has anyone got there and installed it yet? how long did it take?
Old 04-19-2006 | 08:42 PM
  #103
maxpit's Avatar
Id post pics but my camera was stolen like 2 weeks ago. Man this is some nice hardware. It was worth the wait.
Old 04-19-2006 | 10:11 PM
  #104
2K5SS/SC?'s Avatar
WTF? Am I always the last one to get my parts? I'm only in Charleston, SC! I just checked, and mine made it to Charlotte, NC so it will be here tomorrow! Yeah!
Old 04-19-2006 | 11:41 PM
  #105
ENUFPWR's Avatar
EDIT: I found out you have to remove the washers... The pics show the washers installed which are wrong...I've updated the dampner since.
Originally Posted by robstamina
I just found out that you DO NOT want to use the metal washers.. they got added in from the other kits by accident..the newer kits will not have them in it..
the washers kick it off at an angle which you do not want..you want the damper installed as straight as possible.
BTW YOU WANT IT INSTALLED ON THE BRACKETS IN THIS SEQUENCE!!!!
bolt head> rod end>rubber o ring >bracket>nut
if you have it out of sequence you get metallic sounds and potentially harm the damper internals or brackets..
Got mine and installed in 10 minutes... EASY install.
Before I bolted the ETD to the brackets I adjusted mine to 10mm the hardest setting. Took it for a drive and ZERO WHEEL HOP!!!!!! The stiffest setting doesn't cause any harsh vibrations and the car shifts firm and all I hear is wheel SPIN!!!! No more wheel hop. YIPPI
First gear is useless now..lol
THANKS ENGALS!!!!
Took some pictures....
Old 04-19-2006 | 11:47 PM
  #106
max_boost's Avatar
Looks good, you must have flown home from work to get that installed.
Old 04-19-2006 | 11:50 PM
  #107
TurboTechRacing's Avatar
Awesome guys we are glad you like them
Old 04-20-2006 | 01:05 AM
  #108
brydude's Avatar
Got Dampner?
Hey aaron do u have any left in stock?
Old 04-20-2006 | 01:08 AM
  #109
R33P3R007's Avatar
360 L337 User
i will install mine tommorow night hopefully, when I complete the install on my header
Old 04-20-2006 | 09:27 AM
  #110
We have a few left in stock they are going super fast.
Old 04-20-2006 | 02:03 PM
  #111
djt81185's Avatar
Ok so was showing a buddy it and dumped it and i got terrible wheel hop. Checked under the hood today and the mount tabs where the damper mounts are bent. I installed it so no force was required to slide the damper on the bolts because the damper was too long when I got it out of the box so I moved the heim joint adjustment in closer....Now I cant find any of my directions or anything. I just now undid the tensioner jam nut and slid the tensioner assembly nut out about 2 turns and rejammed it...did I adjust it right? Why is my brackets bent already? I dont want to have to keep readjusting it...
Any thoughts?
Dan
Old 04-20-2006 | 02:04 PM
  #112
max_boost's Avatar
Any thoughts?
Dan
Great, that is not a good sign. Can you get some pictures of it?
Old 04-20-2006 | 02:08 PM
  #113
djt81185's Avatar
just looked at the above posted pics and my bolts are on backwards...would that make a difference?
Dan
Old 04-20-2006 | 02:20 PM
  #114
BLKSS's Avatar
So is this the one way road to eliminating wheel hop? Sorry but with all the posts about this I find it hard to believe that you guys actually found a way to stop this..
Old 04-20-2006 | 03:30 PM
  #115
max_boost's Avatar
Dan
According to the directions you can put the bolt and nut either way. The only thing that can't be changed is now the washer and o-ring go on.
I just opened my box and these are some hefty brackets. Not sure how they would bend.
Old 04-20-2006 | 05:51 PM
  #116
robstamina's Avatar
Originally Posted by Smokem10
I heard Ingalls were test fitting it for the redlines earlier this week. Did they figure it out?
it might fit considering it is the same motor mount for 05+ redlines.. gotta make sure first
Old 04-20-2006 | 05:56 PM
  #117
robstamina's Avatar
Any thoughts?
Dan
I just saw the pics you sent to the engineer..we wil have answer for you shortly..
Are your motor mounts shot?
Old 04-20-2006 | 05:59 PM
  #118
djt81185's Avatar
I've had busted motor mounts in my neon before and I know what they feel like. my mounts feel the same as the day I bought the car. Also I checked all of them and there is no ripped material or leaking from any of the hydrauic mounts. From what I see all my mounts are fine.
Dan
Old 04-20-2006 | 06:39 PM
  #119
BooSSted's Avatar
I just got mine and I must say I an NOT very impressed with the finished quality of this piece. It has gouges and scrapes all over it and the edges are all knicked up. It really doesn't look like something I just paid a couple hundred dollars for!
Old 04-20-2006 | 06:42 PM
  #120
robstamina's Avatar
must of got banged around during shipping.. email me and I will see what I can do about getting you some other brackets...
robs@ingallseng.com
Old 04-20-2006 | 06:48 PM
  #121
BooSSted's Avatar
It was wrapped in bubble wrap, haha. Only one of the bracket is screwed up, It's the big one.
My e-mail is mattnoseworthy@cogeco.ca. I have to run right now so you can e-mail me or I will e-mail you when I get back in.
Old 04-20-2006 | 07:08 PM
  #122
robstamina's Avatar
just emailed you..
Old 04-20-2006 | 07:15 PM
  #123
BooSSted's Avatar
Intalled the mount and the marked side of the brackets is on the inside so I am not worried about it. This thing works AWESOME. I notice a very very slight vibration in low RPM's but it isn't bad at all. I had full solid mounts in my Neon and it was terrible for the vibrations. Truth is though, This works as well as the solid mounts I used to have!!
Old 04-20-2006 | 07:16 PM
  #124
BooSSted's Avatar
BTW, I opened the box a half hour ago and in that time I looked over the part, installed it and took it for a test drive. Shows how easy the install is.
Old 04-20-2006 | 07:18 PM
  #125
max_boost's Avatar
So Rob, should we be using the washers that came with the kit or not?
