The new TWM SS Supercharged Short Shifter Review and Pics
It is noticeably shorter than other brands. We made it as short as possible while retaining the reverse lock.
In addition, we found that 5th gear on other brands was vague (when you push all the way to the right and up it wouldn't go right in to 5th) so we designed ours to correct this. The TWM reverse lock also slides on delrin bushings for a very smooth feel. Also, the other short shifter's reverse lock "guide" is a steel spring pin that grinds on the reverse lock when you lift it, the TWM features a cylindrically ground shoulder bolt with o-rings for quiet and smooth operation.
Overall we feel that we designed a superior short shifter, without cutting corners.
Thank you for the positive feedback
Kevin
TWM
Kevin
TWM
Sound like you guys actually did a lot of research and made your products to the right T
Just installed mine, and let me say this is badass and shifts like butter. Installation was easy as I was a first timer and the pics and detail were perfect. took a little longer for me cuz my ******* re-installed the shift boot above the reverse lock like a moron, so i had to redo (thanks for the extra zip tie by the way).
Other than that the only thing i noticed was the allen bolt for the reverse lock calls for a 5/32 to tighten and mine was 1/8. Not sure if this was a typo or my bolt was smaller but it was easy to recognize.
All in all a fine product and I highly recommend this to anyone considering, this is well worth it!!! TWM FTW!!
Frank
TWM Performance
The aluminum base bushings replace the stock rubber bushings that are used to mount the shift assembly to the floor of the car. These rubber bushings flex a lot when shifting and they are part of the vague, unprecise feeling of the stock shifter. The solid aluminum base bushings will eliminate this unwanted play and they also improve the precision of the shifts.
Frank
TWM Performance
Frank
TWM Performance
Frank
TWM Performance
Frank
TWM Performance
looks great. i love the style. i had theirs for my 2.2 and liked it alot but i just like my b&m a lil more, its easier for me to shift quicker.
congrats on a nice mod
Hi Guys,
We just got confirmation that the TWM SS/SC short shifter does fit the SS/TC as well, check out the review here: https://www.cobaltss.net/forums/show...=128742&page=3
They're still on sale until the end of the month, check it out: TWM Cobalt SS/SC and SS/TC short shifter sale
Thanks,
Kevin
TWM
Thanks,
Kevin
TWM
Hi Guys,
Today is the last day for the special introductory pricing, don't miss out! Prices go back to retail tomorrow morning.
Check it out: TWM Cobalt SS/SC and SS/TC Short Shifter Sale
Thanks,
Kevin
TWM Performance
Thanks,
Kevin
TWM Performance
