Twm cable clamp
Twm cable clamp
As anyone had a problem with the cable clamp not fitting on the shifter? It fits so loose that it falls off while shifting gears. The ball on the end of the shifter is smaller than the stock one if I put the cable clamp on the stock shifter it fits tight.
ballin on the budget!!
It's not the adjustment it's where the clamp hooks to the shifter that little bushing the shifter sits in, you just look at it wrong and it falls off.
Josh@ottp
09-08-2015 10:18 AM
