TWM Cobalt, Cobalt SS/SC and SS/TC Short Shifter GROUP BUY!!! **** 15% off! ****
#51
Ill give it a shot and let you know....thanks.
Okay so I just went down and tried that, and as I was doing it I realized I had tried that earlier. It does work....disconnecting both cable clips allows me to get the shifter onto the reverse lock tab....however, once I get it on the tab and go to close the cable clips, the Left cable clip wont close because its on the yellow threaded part. I cant move it off the threaded part without taking the shifter back off the reverse tab!!!!!
Something doesnt seem right. Too bad, because everything else was sooo smooth.
I ended up getting it....it just took a ton of trial and error adjusting with both cables. It was a real tight balance because if I moved it to far to the right, to get onto the reverse lock tab, then I couldnt get into 5th. But if I wasnt far enough to the right I couldnt get on the reverse tab lol. I ended up finding a REALLY small area where everything worked
Shifter feels nice, i especially like how much shorter the throw is from 4th to 5th.
Oh and here are my pics I love the look of it with the other tiny chrome accessories around the interior of the car, it matches nicely. Polished was a good look to go with. Throws are nice and solid now with the STS and the solid bushings. Definately is a nice product to have. The stock shifter does appear to have been rubbery feeling and I didnt even know it A TWM STS is up there with swapping out the restricted downpipe or getting a stickier set of tires. Really does the car justice. Shifter and weight shift knob +solid aluminum bushings were bought at http://www.twmperformance.com/shorts...rt-shifter.htm
now I just have alot of excess *******, i mean shift boot.
#52
redlinegoods.com can make you a new shifter boot that is 1" shorter. also that polished knob is probly gonna get super hot mine does and its machined can barly touch it without burning myself
#53
#56
Vette, where does your reverse lock out sit? Im at the extreme with my left shifter linkage. Anymore and i wont be able to get into 5th gear. My reverse lock sits halfway on the black plastic tab... If I push it over real hard it can seat onto it.... just curious how yours turned out?
#58
