TWM Performance TWM Performance is a proud Supporting Vendor
TWM Cobalt, Cobalt SS/SC and SS/TC Short Shifter GROUP BUY!!! **** 15% off! ****
Old 07-10-2010, 01:49 PM
  #51
CudaJoe's Avatar
Originally Posted by 80vetteL82
Ill give it a shot and let you know....thanks.
Okay so I just went down and tried that, and as I was doing it I realized I had tried that earlier. It does work....disconnecting both cable clips allows me to get the shifter onto the reverse lock tab....however, once I get it on the tab and go to close the cable clips, the Left cable clip wont close because its on the yellow threaded part. I cant move it off the threaded part without taking the shifter back off the reverse tab!!!!!
Something doesnt seem right. Too bad, because everything else was sooo smooth.
I ended up getting it....it just took a ton of trial and error adjusting with both cables. It was a real tight balance because if I moved it to far to the right, to get onto the reverse lock tab, then I couldnt get into 5th. But if I wasnt far enough to the right I couldnt get on the reverse tab lol. I ended up finding a REALLY small area where everything worked
Shifter feels nice, i especially like how much shorter the throw is from 4th to 5th.
I am currently having the same situation. i can't get the plastic tab on the reverse lock mechanism. when I adjust the cable, I cant close the plastic clip due to the yellow threads. and when I get it really close to the yellow threads, I cant get into 5th gear. right now I have all my gears working but the reverse lock mechanism is barely clinging on to the plastic tab and its tearing away some of the plastic which I fear will eventually begone over time. Is there away of fabricating the rever lock mechanism to straddle the plastic tab easier?
Oh and here are my pics I love the look of it with the other tiny chrome accessories around the interior of the car, it matches nicely. Polished was a good look to go with. Throws are nice and solid now with the STS and the solid bushings. Definately is a nice product to have. The stock shifter does appear to have been rubbery feeling and I didnt even know it A TWM STS is up there with swapping out the restricted downpipe or getting a stickier set of tires. Really does the car justice. Shifter and weight shift knob +solid aluminum bushings were bought at http://www.twmperformance.com/shorts...rt-shifter.htm
now I just have alot of excess *******, i mean shift boot.
Old 07-10-2010, 03:30 PM
  #52
richsoucie's Avatar
redlinegoods.com can make you a new shifter boot that is 1" shorter. also that polished knob is probly gonna get super hot mine does and its machined can barly touch it without burning myself
Old 07-10-2010, 04:44 PM
  #53
80vetteL82's Avatar
....you said polished knob..... lol
Old 07-14-2010, 12:07 PM
  #54
CudaJoe's Avatar
hey is the 10$ back thing real when posting up pics on websites? I filled out that form awhile ago and havent heard anything back yet?
Old 07-14-2010, 12:11 PM
  #55
80vetteL82's Avatar
Thanks for the great product guys!!
And congrats on a very successful GB
Old 07-14-2010, 12:29 PM
  #56
CudaJoe's Avatar
Vette, where does your reverse lock out sit? Im at the extreme with my left shifter linkage. Anymore and i wont be able to get into 5th gear. My reverse lock sits halfway on the black plastic tab... If I push it over real hard it can seat onto it.... just curious how yours turned out?
Old 07-16-2010, 03:37 PM
  #57
Bannned
ColeJJones's Avatar
just ordered. hopefully i can get a late refund
Old 07-16-2010, 07:12 PM
  #58
80vetteL82's Avatar
Yeah, mine was the same issue. I just really took my time and kept making VERY VERY slight adjustments to both cables and retesting it after every adjustment. I finally got it to where every gear works and its far enough up on the reverse tab. I do have to make sure I really push the shifter over to the right to get all the way on the tab though....
Old 07-16-2010, 07:14 PM
  #59
richsoucie's Avatar
that will stop after about a week of use i had the same prob with it not going on smoothly it went away completly after a couple days
Old 07-26-2010, 05:07 PM
  #60
SRodSS007's Avatar
i missed out =[ im deployed lol and just fouind the link damn you army...damn yoooouu!! plus i dont get paid till the first
WhineSSbaby
09-01-2020 12:39 PM
turboecotec02
11-26-2015 10:43 AM
ashalle2
09-16-2015 10:36 PM
Jacque8080
09-09-2015 09:21 PM
Bluelightning
09-08-2015 05:18 PM
Quick Reply: TWM Cobalt, Cobalt SS/SC and SS/TC Short Shifter GROUP BUY!!! **** 15% off! ****
