TWM please fix our shift linkages!
I had the same issue in my 2007 LS I ended up replacing that ball socket connector because it wasnt as resilliant and it should be. It's not TWM's Fault that little plastic socket just sucks is all.
Hey guys,
It's a project we're working on. Basically replacing the stock plastic part with an aluminum part and a much more solid attachment point. No ETA at the moment, but keep an eye on our section for any further details!
Thanks,
Frank
Team TWM Performance
Thanks,
Frank
take shifter out, remove ball with vice grip, the threads are something like M6-1.25 pitch or something small, you will need two fender washers, a 1.25 inch long bolt, RED loctite, a drill, your original plastic socket end to the shifter, about thirty minutes of your time and the slightest tweak to get it to feel right.
Hey guys,
We have some great updates! The clamp is tried, tested and works AMAZINGLY! There are only a few more tests to do and you guys should have an update by the end of this week...We're almost there guys, so just be patient for another few days!
To hold you all over, here's a teaser of our prototype piece:
Check out the official Pre-order thread going on RIGHT NOW!
https://www.cobaltss.net/forums/twm-...-order-235464/
