F35 transmission
I have two, but they're both in limp mode, so to speak. One LSD, one open; both 4.05 FD.
The LSD transmission had metal shavings in the last oil drain (the LSD is a sealed unit, so no worries) and the Open has a bad second gear synchro blocker ring. If you don't mind some internal work, you could move the LSD and the synchro over and have a complete 19k mile transmission.
Mississippi is a bit of a haul, but if you wanted to pick them up, I'd give you both for $495.
I now live in Corpus Christi Texas, just haven't changed location on here. is there a shop here in texas that can make that switch? it has been a long time since I have worked on one of these transmissions. really I only need the case and Lad out the one. my case is leaking since my son blew the clutch up. gears are all fine.
I will also throw out a place. I am not sure if they do it, but the welded up a crack in a TH400. They are a huge shop in Fort Worth. Might be worth a call. There is also a few performance transmission shops in Kennedale.
https://www.yasabe.com/en/fort-worth...smissions.html
