06 Stage 2 SS/SC vs Modded STI
#52
dude go from 40 dont listen to him i can beat a stock sti from 40 did it already (it might have been modded even the bov was like an extremly loud screech instead of shh) any way i got him till i stopped at like 90 he was way behind from 60 tho lot closer of a race neck and neck till 100 or so then he started to pass
#57
lets set things stright guys. sti's have a **** ton of lowend torque so you have a better chance if anything of winning from a higher speed, which again is unlikely. i highly doubt a cobalt stg 2 which is some spark plugs would win against a stock sti. a cobalt w/intake and whatnot would not be able to pull on a stock sti. sti does 0-60 in under 5. 06,07 stis do it in 4.5 seconds.1/4 mile in <12.9. anywho it does not take 10k to upgrade a turbo as posted earlier. upgraded turbo, if he was smart hed get himself a gt35r w/antilagg
Cliff notes: it doesnt matter if its a stock sti, you would not beat him unless A) hes trying to eat mcdonalds while shifting or B) he mishifts.
also 2004 is the rawest usdm version of the stis
#58
ahhhhhhhhhhahahahahahahaha
ahhhhhahahahahahahaa *cough* ahhhahahahahaha *cough cough*
*giggle*
you tho thilly.
#59
well how bout you go drag your butt to the stealership and test drive one, its the sad sad truth. im dead serious a ss cobalt would get walked one by a stock sti, there are lambos that get walked on by them. please shutyour mouth
#60
in your defense, maybe you are just referring to dig races in which you would be completely correct. if you are referring to digs AND rolls, then you are wrong about the stuff that you said. the cobalt has proven itself plenty of times against STi's from a roll. lets face it though, EVO's and STi's own dig races.
#61
Originally Posted by Mines_Better
stage 2 is just spark plugs? hmmm maybe i shouldnt get it then... hahahahaha! sorry man, you are dead wrong in everything that you have stated. i dont really like to argue with people on here, but you are about 50,000 miles from knowing what you are talking about.
at least someone understood.
Im laughing at the fact that you come in here trying to "elighten us" with the truth....and you think stage 2 is spark plugs?
as ive stated before. STI is a dig monster, but if your talkin about highway.....you will have a "WTF" look on your face as a stage 2 I/E cobalt pulls you.
#62
Oh man the last few posts here have been great! This dude doesn't have a clue! Must have been real bad then for my buddy when he downshifted in his fairly stock EVO next to me at 40mph, and when I realized what he was doing I downshifted into 2nd and put 5 cars instantly on him with my current mods. Noooooooo....that wouldn't happen to the beloved EVO or STI though.
#63
GM Stage 2 Kit
AEM Dry-Flow Filter
Ingalls TD
NGK 1-Step Colder Plugs
i did not state really anything wrong in the point im making, seriously guys i think youre the ones with no clue. not to mention the sti has an upgraded turbo. stis from digs kill, yes. i beleive an sti will easily take a ss, if you think not well.. not much i can do about that. fwd does have the advantage over awd in this case, but like i said 300awhp compared to like <240 at crank at max? fwd helps but not that much.. what you said about traction issues well, he must suck at life. you guys should reconsider at ppointless little drag race and do something that takes skill. go to an autocross and compare standings or race on a fun little twisty road.
wait a minute we talking bout one of these right?
for a second i thought we were talking about evos! cough.cough. they are slower .cough
dude ss vs sti just doesnt compare, different leagues. although it is ones nature to defend the type of car they have. sorry no i dont have an sti.
for the giggles here is how the stats compare.
06 cobaltss
Engine Configuration I
Cylinders 4
Aspiration/Induction Supercharged
Displacement 1998.00 cc | 121.9 cu in. | 2 L.
Valves 16 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 205.00 BHP (150.9 KW) @ 5600.00 RPM
Torque 200.00 Ft-Lbs (271.2 NM) @ 4400.00 RPM
HP to Weight Ratio 13.6 LB / HP
HP / Liter 102.5 BHP / Liter
Redline 6450
Bore 3.39 in | 86.1 mm.
Stroke 3.39 in | 86.1 mm.
Compression Ratio 9.5:1
Fuel Type Gasoline - Petrol
Fuel Feed sequential multi-port fuel injection with hig
Block Aluminum
Head Aluminum
2004 sti
Engine Configuration O
Cylinders 4
Aspiration/Induction Turbocharged
Displacement 150.00 CU IN. | 2458.5 cc. | 2.5 L.
Valves 16 valves.
Valvetrain DOHC
Horsepower 300.00 BHP (220.8 KW) @ 6000.00 RPM
Torque 300.00 Ft-Lbs (406.8 NM) @ 4000.00 RPM
HP to Weight Ratio 9.9 LB / HP
HP / Liter 120.0 BHP / Liter
ok done
AEM Dry-Flow Filter
Ingalls TD
06 cobaltss
Cylinders 4
Valves 16 valves.
Valvetrain DOHC
Redline 6450
Block Aluminum
Head Aluminum
2004 sti
Cylinders 4
Valves 16 valves.
Valvetrain DOHC
ok done
#64
GM Stage 2 Kit
AEM Dry-Flow Filter
Ingalls TD
06 cobaltss
Cylinders 4
Valves 16 valves.
Valvetrain DOHC
Redline 6450
Block Aluminum
Head Aluminum
2004 sti
Cylinders 4
Valves 16 valves.
Valvetrain DOHC
ok done
AEM Dry-Flow Filter
Ingalls TD
06 cobaltss
Cylinders 4
Valves 16 valves.
Valvetrain DOHC
Redline 6450
Block Aluminum
Head Aluminum
2004 sti
Cylinders 4
Valves 16 valves.
Valvetrain DOHC
ok done
your STILL making yourself look like an idiot.
Stage 2 with aem dropin and plugs with an ETd........240 at the crank huh.....go look in the 2.0 performance section right now...theres a discussion about a few guys who recently dynoed COMPLETELY STOCK at 229hp AT THE WHEELS.
those mods will put a cobalt at 240-250 at the WHEELS chief.
Keep thinkin these little cobalts have 205hp at the crank.
cuz its funny as **** when you learn it the hard way.
Take your magazine racing and shove it.
dig....you win.
roll....you lose.
end of discussion.
#65
man, magazine numbers do not mean ANYTHING. everyone should know that by now. you cant just pull numbers out of there and sound smart. STi... stock, 300hp at the wheels? not a chance. definitely less. SS... stock, 205hp at the wheels? HELL NO! definitely more. add stage 2 and, POOF, the SS is quite a contender.
and i dont wanna hear all this, "oh well if the STi was cobb stage 2 then it would be all over!!!" the core of the topic is a SS getting mods and being able to hang with the faster cars when they are still in stock form, in which this has been done. this doesnt make the SS a better car, no one here is saying that it is, because the reality of it is... its not.
its fun to beat an STi though!!!
#66
If you want to magazine race go to the newstand and stand around it. If you want to come on and troll...don't and if you want to come on talking trash, spewing wrong figures, and being rude then please...go over to the civic forums...they are good at all of that and you should feel right at home.
As far as your Lambo comment..please show me a stock STI beating a lambo...i think everyone here would love to have you go away and search for that vid, because you would spend the rest of your life searching and not finding, which would translate into you going bye bye.
Go troll somewhere else...or better yet...go take a ride in a stage 2 ss/sc and then come back. But until you know what you are talking about...lets keep the posting of guessing and incorrect statements to a minimum ok.
#68
STI that FNFAST is supposed to be racing has over 300awhp
