20-70...SSSC vs. 5.7 GTO
Rattlesnake Race Shop
How do you know that the Cobalt SS/SC that you raced didn't just have a bad driver? Same can be said for both cars... as I've seen some REALLY shitty SS Drivers. BUT, I do agree... that a PLAIN GM Stg2 with the GM tune... SHOULD not beat a 6.0L.
If he ran my LS2 GTO on a day like today after I have been driving around for an hour or two, he would probably be able to hang with it. I do not know if heat soak kills the LS1's like the LS2's, but the car turned into a dog in these southwest Georgia summers after driving for a while. A tune supposedly helped with that, but I never got around to it.
My experience with GTO's dictates that all LS1 and LS2 GTO's do not run the same. Some are weaker, some are stronger. That experience is from GTO to GTO comparison. I suspect that it is much the same with SS/SC's too.
But I would agree that every SS/SC is different as well. Some just put out more than others. Mine is a *****... and puts out REAL good.
good race holding off the goat man
so just cause the a4 will trap a little over 100 and the SS/SC around 98 thats what makes it plausible? Its a ****** street race from 20 to 70 and the balt got a little jump and maybe the gto sucked at driving and so on and so on! anything can happen in a street race thats why it is plausible
Also it would be pretty hard to suck at driving an a4
Very true, but it also would have obvious signs in a race. If he was that bad at shifting, the SS/SC would have gained some ground.
#37
Exactly. Based on the description the OP gave, no one gained anything. So there are either two good drivers, or the GTO was an A4. I raced an intake/exhaust SS/SC in my LS2. I would say it was comparable to an LS1 GTO to 90mph, in my area at least. That same SS/SC still lost after he added Stage 2, but he put up a better fight, and he was definitely faster than any stock LS1 GTO I ever ran across.
#38
I have to take a
#39
Everyone else's experience may vary. I never personally witnessed an SS/SC at all against an LS1 GTO, but I raced several LS1 GTO's (M6 and A4), and I have my experience against an intake/exhaust SS/SC and the same SS/SC after Stage 2. I do not know if he stuck with the GM tune or went custom, or if he was running a smaller pulley than Stage 2. I am more inclined to believe straight GM Stage 2. He was not a member here, and I doubt he did his homework. At intake/exhaust, I would call him even with a stock LS1 GTO, especially in a short race like the OP had. After Stage 2, I would say he was faster than a stock LS1 GTO.
#40
#41
https://www.cobaltss.net/forums/drag-racing-52/new-stage-2-record-102717/
He will go 12's this year, I guarantee it.
#42
It was not a Stage 2 only car, it was Stage 2 with intake/exhaust. None of those "races" were conducted at a drag strip either. Would have been a very different result there. I would say the average LS1 GTO traps anywhere from 102 - 105. Lower and higher are not unheard of. I know that all of the stock GTO's I played with (LS1 and LS2) were not equal. Some could pull a half car or more on their counterparts, and some ran even. I never ran across a freakishly fast stock LS1, but I am sure they are out there. That particular SS/SC might be a freak too.
#43
Man I hope I can hit 12's
Anyways the races seem to be close but as soon as 100mph comes around it sees like auto or manual the gto begins to pull or catch up or whatever, idk if its gearing or what, but I remember third gear in my ss/sc being quite a bit slower than the others.
#44
Fourth gear is where the s/c falls on its ass.
PS. My third gear is what beats gt mustangs.
#45
And it's because once you start getting into the upper mph range, weight becomes less of a factor, and more HP becomes a BIGGER factor.
Agreed... upper mph of 4th seem to suck ***** in my SS. It just seems like it takes forever to pull.
#46
idk I had a catless full exhaust 2.8 pulley 60lb injectors k&n intake and a tune from Witt and abunch of other **** I prolly forget by now and it just seemed like thats where it started to fall, idk maybe it was just me. But the gto pulls steady all the way through those gears.
#47
The top of 3rd is where my LS2 really shined. 3rd in my SS/SC does not seem as strong as 2nd does, but by that point you are moving fast enough that perception is not really the best measuring stick. 3rd in my LS2 did not "feel" that it punched as hard as 2nd, but it actually punched harder.
#48
**** I hope it does. If gas and insurance wasn't high on them, i would of got a 6.0
#50
Yea I have meth and It makes a big difference. I can literally hold my hand on the sc and it is just alittle warm after alot of pulls in 90 degree weather.
