cobalt ss/sc vs. RSX-S
Originally Posted by Xenozx
thats a flywheel Dyno, how does one dyno HP and TQ at the flywheel?
It is interesting to see HP jump like that once Vtec kicks in. I am a noob when it comes to vetec but is it possible to be in that Vtec mode the entire time, if you do something or modifiy it somehow? Is there a way to get Vetec on say a car other then a honda engine built with it? Its basically Variable Valve timing right? Why cant another car use the same principles?
Originally Posted by FastFrontier17
you have to understand that hp is most likely at the hubs...its a higher compression, protuned rsx...head gasket, type r throttle body, toda race header, toda exhaust, toda N2 cams...most likely on race gas...but about vtec...other companies have like VVTI (toyota) and **** like that...i-vtec is vtc and vtec...3rd lope that extends the duration that the valves are open...allowing more air a fuel...the k20a2, z1 & a1 have a good head on em too...they flow like crazy...
Vetc sounds interesting, I will have to take my friends prelude for a spin, just to see what it feels like.
vtec is fun...but torque is better, i used to own a rsx and it just got too boring for me after the 1st month of ownership. the only way i would ever own another one would be if it was turbo'ed already. i miss the styling of it, but the ss does my fine in that area...heres a pic of her...
but i dunno how long your buddy has been driving the car but ive taken on a local rsx who is a buddy of mine and has ips cams, kpro, cai, rh, and exhaust and dyno's around 210ish and we stay right beside eachother the whole time. only time one of us loses any ground is when we shift and we gain it right back...its the damndest thing...lol...we did it three times and no real results. but that was when i was stock. and he doesnt have a good tune yet either...
Hubs? I just saw what the dyno chart said it says "Fly Wheel Power - Hondata 2005"
http://auto.howstuffworks.com/question229.htm ... as fast frontier said earlier I-vtec also has VTC, variable timing control which advances and retards the timing in the different RPMS. SVT Focus has a VTC system. I am not sure what other cars do but I am sure there are other cars with it. I also believe Honda is still the only ones that VTC and VVT variable valve timing on the same engine.
Originally Posted by wasey13
Meaning you take your wheels off and the dyno hooks to your wheel bolts. And it is used to estimate/measure power at the flywheel.
a good protune should give him a good bit more power...if hes using the base map that is...ive seen bolt-on rsx's with k-pro with a pretty moderate tune actaully hit around 210
#36
yeah hes lookin at about 220ish with a good tune...hes new to kpro and cant figure out how to tune it for the cams...hes just gonna wait and take to someone who will do it right instead of screwing it up
#38
Doesn't Hondata have a base flash for the cams already that you can tune from then? Tell him to just ask call Hondata and ask as many questions as he can and tell him to ask a lot on clubrsx.
#39
#40
yes they have a base map but its really conservative...id say that its good for basic driveability until he can get it to the tuner
#41
Nobody has one that is more aggressive? That he can start from? The cams have been out for a long time now.
#42
every car is different...and no one really wants to pass around a calibration...would you pay 300 bucks for a tune and then someone ask you for it?
#44
I realize that every car is different. Not everyone paid 300 for their tune(some did it themselves) and honestly I probably would share mine either way. What do I have to gain or lose, by sharing or not sharing?
#45
this has turned out to a very informative thread. i personally wouldn't use someone else's calibrations due to not every motor is the same. i will be upgrading to k-pro once i start getting more bolt-ons. just have cai right now so #4 reflash is fine for me. i'll most likely get k-pro once i get my dcrh, greddy evo2 & ips cams. and fastfrontier17, your car is definently a sleeper. i'll trade you my "show" mods for your "go" mods. lol
#46
#47
other than that, DC5, don't trade your looks. your car looks bad ass. just save up and get some go fast goodies.
#48
Originally Posted by ralliartist
Yay for me!!! i have MIVEC!!!! my car is one you forgot to mention. altho it's still a fairly new design. but my car has the timing control and lift technology also. you actually can't even advance the timing without using ecu. there is only one way, and that is to drill into the cam angle sensor bolts and adjust it there. but it's almost pointless cause the mivec engine is already so aggressively advanced that if you go any further it requires higher octane so you don't detonate. just thought i'd add that.
Anyone know about Mazda's new MS3 engine if it has VCT to go along with the VVT and direct injection?
#49
I was just thinking there was a more aggressive starting calibration. That might help the guy see where and how he needs to tune.
this is what you get to start with
#50
I thought MIVEC did just wasn't for sure, but isn't it only on the exhaust side? Not the intake side too?
