cobalt ss/sc vs s/c cobra terminator
#76
my points are as follows:
there are way more to add into this equation that power and weight. none of you have accounted for the relative aerodynamics, rolling resistance, gear ratios, or various other conditions.
for someone that is saying weight makes less of a difference the further you go, please show me proof of this. you are still trying to make the same object increase the same speed, and in a vacuum, it SHOULD take the same amount of work. therfore, the weight isnt becoming any less important, but other factors MAY play an additional large role in determining results. (ie: aerodynamics)
#77
i would like to see some scientific evidence supporting his claim anyways. im no physics major, but it appears to me you are still trying to get X amount of weight to move X distance. if you are accelerating the same car from 0-20 mph, and again from 20-40, why is the weight less of a factor in the 20-40 one? momentum on a flat plain isnt going to aid acceleration.
you didnt catch the sarsasm in my above post you are referencing.
was that, really that hard to figure out?
#78
2003 -2004 Cobra Engine/Drivetrain
2003 -2004 Cobra Engine Displacement 4.6L 281cid DOHC Modular w/Eaton Supercharger
2003 -2004 Cobra Compression Ratio 8.5:1
2003 -2004 Cobra Horsepower 390 hp @ 6000 rpm
2003 -2004 Cobra Torque 390 lbs.-ft. @ 3500 rpm
2003 -2004 Cobra Transmission Tremec T56 Six speed
2003 -2004 Cobra Rear end IRS 8.8″ 3.55:1 w/traction lock
2003 -2004 Cobra Suspension
2003 -2004 Cobra Front Modified Macpherson strut type with Bilstein struts, linear rate coil springs, and 29mm anti-roll bar
2003 -2004 Cobra Rear Multi-link independent with upper and lower control arms, linear rate coil springs, and 26mm anti-roll bar
2003 -2004 Cobra Brakes
2003 -2004 Cobra Front 13.0 in. (330mm) vented Brembo disc, PBR twin-piston caliper
2003 -2004 Cobra Rear 11.65 in. (296mm) vented disc, single-piston caliper
2003 -2004 Cobra Anti-lock Brakes/Traction Control Four wheel anti-lock with traction control standard
2003 -2004 Cobra Wheels/Tires
2003 -2004 Cobra Wheels 17 x 9 in. 5-spoke cast aluminum
2003 -2004 Cobra Tires Goodyear Eagle F1, 275/40ZR-17
2003 -2004 Cobra Other General Specifications
2003 -2004 Cobra Wheelbase 101.3
2003 -2004 Cobra Length 183.5
2003 -2004 Cobra Width 73.1
2003 -2004 Cobra Height 52.5
2003 -2004 Cobra Front/Rear Track 60.3/60.3
2003 -2004 Cobra Weight Coupe: 3665 Conv: Aprox. 150lb more
My fathers Cobra dynoed on a dyno jet at 372 with x-pipes. who ever wants to believe they have 425 to the crank and are underrated need to go speak with him. Those stat are listed directly from ford and the stats i gave are real numbers from a dyno. stop talking **** to the kid just because you retards dont want to believe he did good against a cobra. if all your going to do is bash his progress and happiness then get the FU'k out of this forum other wise shut the hell up.
Congrats man nice job.
#79
#81
Pullied cobras have trapped mid 120's but the norm is high teens depending on da. What some people over look is these motors were hand built none of them dyno the same. Some dyno low some dyno 390whp if you dont belive me ask Unit over on LS1tech what his car dynoed, Im pretty sure it was right around that mark. Exhaust cobra should easily be a 115 mph some stock cobras have trapped 113.
#82
Still don't quite get it as on several occassions I've beaten cars that had much more whp than I did from a Roll. Though they did weigh quite a bit more.. Persay this way.. Take a Stock Mustang GT 99-04 and a Stage 2 LSJ, same whp.. A roll and the Cobalt will walk hard every time..
I raced plenty of honda preludes [h22's] from a roll in my GTI and i would pull away from then when really the Honda has near the same hp yet it weight significantly less.
#84
I have a hard time believing this story. I was in my buddies 04 termi and after about 60 it pulled pretty hard bone stock. Now Ive raced plenty of SSs(stock and modded) and I just cant see a two and 1/2 car loss. I think itd be more like 4-5. But hey, I guess anything can happen.
#85
that also has to do with useable power bands, the cobalt has a much more broad power band being its SC'd compared to a 4.6L N/A.
I could be wrong, I just don't see it Sorry man
2002 = Non Existant Production Car
#86
I take it you dont know that much about cobras, its pretty obvious so Ill break it down nice and simple for you. Almost all pullied cobras run the same upper pulley on the blower some run a lighting 4lb lower to boost it more. There isnt a whole plethera of pulleys for these cars like cobaltsas well as there isnt that much difference between pullies for these cars. After pullied cars have been pullied for a while the next cheap route is porting the blower.
#87
#89
Okay.. I used a bad example.. The same car... 2 LSJ's with the same exact whp and same exact mods.. Now, 1 lsj has 400 pounds in weight reduction... Which one will win from a roll.? I know which one I'd put my money on.. I guess I just don't get the "physics". I do understand common sense though..
#91
#95
#96
does it? can you show me this? (taking aerodynamics out of the equation) you simply claimed weight makes less of a difference the higher you go up, i dont believe this is true.
#97
I don't have time right now to detail, but I am saying it makes less of a difference. Now taking to same HP cars with the same TQ yada and putting them into two different weight body's you know the out come. But take a more powerful car with a higher power to weight then a less powerful car with a better power to weight that difference becomes alot closer the higher they go.
I should have been more clear we are talking about two different cars with two different weights. IE cobra versus cobalt. I am not sure I have something to show but their are plenty of examples out there in the real world of racing. Pretty sure you won't be able to find a physics example of two cars racing at speed, but let me know if you do!
Tyler
Tyler
#98
Tyler
Tyler
#100
ever driven an older car that isnt power steering? try turning the wheel while standing still, it take a decent amout of force to move it because there is a great deal of friction between the tires and the ground.
now take said car for a cruise and see how easily it turns no compared to when its stopped.
i can keep going. . .
