GTO vs SS/TC and C6
#177
#181
#183
#185
^ wow that takes *****. im not lying i felt the car was not stable at all above 140 ish.
could you send me the video? mtarrant07@aol.com id really like to see it thanks
#186
sure, ill load it to the computer after work and send it. car felt stable to me, had full suspension, it was a dead straight road ( RT 11 ) if anyones from CT theyll know it.
#189
#191
Think about it though: 454whp C5 Z06 3200lbs vs 415whp Cobalt 3100lbs
I have done 180+ in my C6, 160mph GTO and went all out (160+) in the 2002 Sandhills classic in my 2000 Camaro SS. I am pretty familiar with what feels stable and what doesn't.
But there are many variables that affect how the same car will feel at high speeds be it tires, tire pressures, road surface and driver abilities.
You can quit trying to be funny about this because it's the truth. If a GTO owner doesn't buy the red stuff they buy the blue stuff if not Magnacharger it's APS or a cam.
If you want to be original pick up a Harrop TVS series Eaton S/C and throw it on.
#192
What are you running a custom grind, quit trying to side step the truth.
Seriously what the hell do you think isn't cookie cutter about most modded GTO's? Most run Pedders crap not because it's the best but because there are no other companies that make everything needed. After that it's either this S/C or that turbo system and so on thus making most modded GTO's very similar.
Get over it.
Ok so say he maintained a near stock weight then knock off the 100 or so pounds then, it still doesn't make sense.
#196
Well in that case ALL cars are cookie cutter cars I guess. Only so much stuff exists before you HAVE to start running the same parts as the guy down the street. Think about it.
#197
He knows the main reason I called his car a cookie cutter modded GTO is due to his pedders stuff since 90% of other GTO's do the same thing. It also sucks that most of the parts available are made by the same place just painted differently.
All in all this comment was made to chill out some of the GTO owners that think there is nothing better.
#198
You know what I mean when I specify GTO's especially once you take the engine and transmission out of the equasion.
So somebody that actually MOD's their car is being a "cookie cutter"....
Well then damnit I love cookies.
And actually some of the parts I am using I have not seen on many goats...
