me vs. 06 evo mr
Originally Posted by ted5986
okay well correct me if i am wrong..but arent the Evolution MR s like 400 whp and not available in the usa. he did say evo mr right?
Originally Posted by the1&only
No it isn't. The biggest problem is the turbo and then for the pre 07 STIs gearing is the next biggest.
Originally Posted by 8cd03gro
roll racing is the weakest point for any awd car... not just turbo awd cars. AWD robs ALOT more power than fwd and a considerable amount more than rwd.
I think kill stories should be locked out immediately without video.
Hey I raced a c6 and smoked him...buslengths..
Lambo...same thing...smoked...
Viper...no problem...waxed him...
and I'm stock.
I think you get me point. Why would you have a passenger in your car if he isn't filming????
and I'm stock.
Originally Posted by Darksun
Yeah you would think but than when you watch the AMS evo vids on youtube your like "WTF" evo's got the same amount of hp as the other cars but still whooping up on them. wheres the Drivtrain loss there. No need for me to post vids every one and there mom has seen or heard of them.
it is a fact that awd has alot more drivetrain power loss than the two other setups in the average setup.
do you have any idea how much has been put into that evo? it is putting out about the same >>>WHP<<< match it up against a rwd car with the same type of tranny, same weight, and same crank hp in a roll race and it will make that ams evo its bitch. That car is rediculous tho.
The reason i used that exsample is because at the time of those vids the ams evo was still int he 600WHP range same as all the other cars it was racing. Its wasnt like it was making 1000 WHP and they were only making 650. watch the vids they tell you what it was dynoing at at the time of the vids
yea and once again that is wheel horsepower...you know AFTER the drivetrain power loss. Compare a 600 crank horsepower awd car at the same weight, with the same gearing as an equally equipped rwd car and it will get owned from a roll. You are failing to see the point here. That is why most other 300hp cars will take evo's and sti's from a roll, along with other things, but that is a major factor.
can't nit pick the small details its bad enough they had to go from rolls can't say "Well i lost cause you make more crank horse power than me even thoguh or Whp Hp is the same."
#36
and I'm stock.
and I'm stock.
#37
Originally Posted by cblt12
damn calm down... i didnt say that i killed anyone... i just wanted to share w/ everyone what happened when i raced my friend... you dont have to believe me and im sorry that i dont just carry around a video camera in my car at all times... o and my passenger was in the car because he happened to be w/ me, next time i will make sure i drop him off before the race...
#38
Originally Posted by OniMirage
evo mr's have been here for a long time and no are not 400 awhp here in the states. ... back to that race what gear did you actually start in?
i guess that is what i was thinking of . . i saw this thing on speed channel about it last year and i could have sworn that he said evo mr. i guess i didnt oh well
thanks for setting my mind straight
#39
awd cars having bad top ends isn't necessarily because of the efficiency of the turbo... it's the huge drivetrain power loss compared to fwd or rwd. The efficiency of the turbo may be PART of the problem, but the biggest problem is the awd itself.
#40
#41
Originally Posted by evolve
Ill explain it for all so you know. If you have a small turbo, you sacrifice top end power(hence the lack of top end from evos and stis when stock), BUT you will have a very responsive(ie fast spool/little lag) turbo when boosting. Larger turbos on the other hand are made for top end power, BUT they arent responsive(ie LAG!!!!) as their smaller counterparts.
#42
yes, but still, compare an evo or sti with a car with the same top end power figures and all else equal except for giving the other car a rwd or fwd drivetrain and it will make the evo/sti its bitch from a roll. The turbo doesn't "limit" its top end at all, as that IS the top end power of the motor as it is, but the awd does limit its power to the ground making it weaker from a roll. What you are saying makes sense, but not in the way it is being stated imo. Look at an srt-4 for example. Fairly small turbo. Not tiny, but pretty small. Stronger from a roll than from a dig because of traction issues. Now an evo or sti, is much stronger from a dig because of 0 traction issues, but the drawback of awd is from a roll it is quite a bit more leeching than a rwd or fwd drivetrain. You are totally right in what you are saying, i just think when you say they are slower from a roll BECAUSE of their turbo, you are kinda saying it wrong. Yes you could make some monster top end with a bigger turbo, but what is taking away from the top end is the awd.
All that matters from a roll is WHP in the upper RPMs, it doesn't matter if it R,A, or FWHP. The SRT-4 keeps making power up to redline. The STI and EVO's HP start to drop off in the higher RPMs when stock due to the turbo running out of breath. And then the pre 07 STIs gearing is horrible from a roll.
#43
JUST QUIT!!
#44
You know i agree with you both but im siding 60/40 with the 1&only because once the Evo's or sti's get a bigger than stock and start getting up in 4-600 WHP that whole Drive train loss complaint doesn't seem to effect them as much. I just dont hear that cmplaint anymore by that point there all for Rolls and hold there own too......
If you go on to the Subaru boards a lot of the guys with the power to run deep into the 10s are barely hitting mid 11s, so they give up and start suprising people from a roll because "everyone knows AWD sucks from a roll."
#45
Actually most of them turn into freeway queens when they do get up into that power range, because A) They suck at driving with that much power and B) Stuff starts breaking.
#46
Ha everytime i lose to an AWD drive car from a roll it hurts my soul just a little bit more than if it was RWD or FWD because i was so wraped up in the belief that since it was AWD That i should have the Advantage almost disreguarding any other factors. Its a lie people on the interweb have been force feed and grow up beliving when its not 100% true. **** some mean as gearing alone on an AWD car will have them holding you off for a good long while.
#47
You know i agree with you both but im siding 60/40 with the 1&only because once the Evo's or sti's get a bigger than stock and start getting up in 4-600 WHP that whole Drive train loss complaint doesn't seem to effect them as much. I just dont hear that complaint anymore by that point and there all for Rolls and hold there own too......
#49
riiiiggghhhttt because thermodynamics being on my side means nothing.
Thermodynamics involves movement of fluids, be they gas or liquid. Stop trying to sound smart.
#50
Originally Posted by cawpin
The only part of drivetrain loss that is Thermo is in an automatic transmission. The rest is simple dynamics.
