Raced a Trailblazer SS
I pulled 1.76 60's on the stock tires.. all about weight transfer and the RIGHT set of wheels driving the power home
had a FWD GP GXP went 13.6 stock.. with a 2.01 60', could barely leave at 1/3 throttle in that car..
$30.5k it's an LT II, loaded exc for Nav/DVD
i did not know gxp's were that fast stock what was the trap speed
#36
I'm having a hard time believing this. How in the hell do I dust GXP's in my Cobalt which runs a measely 14.4? I've beaten GXP's at the track or on the street, stock and slightly modified! Unless you are talking about the GXP with the displacement on demand V8, then I totally believe you. If your speaking the last generation with the SC/V6, I have to call BS! Do they call the new Grand Prix with the V8 a GXP?
#37
The SC/V6s were GTPs
#38
#39
2004-05 GP GTP = 3800 V6 Series Supercharged
2006+ GP GXP = 5.3L V8
GXP = SS/SC in 1/4 mile stock for stock.
#40
#41
Another independent study has this
Engine : V8, DOHC, front engine FWD
Displacement : 4,565 cc
Valve : 32 valves, 4 valves per cylinder
Transmission : 4-spd automatic
Fuel economy : city - 17 mpg
highway - 24 mpg
Suspension : F - Independent MacPherson strut
R - Independent MacPherson strut
Brakes : F - Vented discs
R - Solid discs
Horsepower : 275 hp @ 5600 rpm
Torque : 300 lb-ft @ 4000 rpm
Redline : 6500 rpm
Top speed : 138 mph
0-60 mph : 6.6 sec.
0-ź mile : 14.8 sec @ 95.0 mph
60-0 braking distance : 126 ft
200 ft skidpad : 0.81 g
Curb Weight : 3790 lbs
Overall length : 202.6 in.
Wheelbase : 112.2 in.
Overall Width : 74.2 in.
Height : 56.6 in.
It's also a heavy car. but I've seen them at my track run low 14's. Something fishy with a 13.6 time. That car had to have a hella 60'fter.
#42
Maybe with Drags. It's only a 14.3 1/4 mile car w/good driver.
highway - 24 mpg
R - Solid discs
Redline : 6500 rpm
Top speed : 138 mph
0-60 mph : 6.6 sec.
Height : 56.6 in.
highway - 24 mpg
R - Solid discs
Redline : 6500 rpm
Top speed : 138 mph
0-60 mph : 6.6 sec.
Height : 56.6 in.
What kind of 60' does it take to get the new mustangs in the mid-13s???? Exactly.
#43
highway - 24 mpg
R - Solid discs
Redline : 6500 rpm
Top speed : 138 mph
0-60 mph : 6.6 sec.
Height : 56.6 in.
highway - 24 mpg
R - Solid discs
Redline : 6500 rpm
Top speed : 138 mph
0-60 mph : 6.6 sec.
Height : 56.6 in.
#45
C&D and MT mags don't or I should say "didn't" take the time to perfect the 1/4 times as I have, and most other GP GXP driver's.. spinning the tires out to the 60' will net you a mid 14 and you haveto hold 2nd gear until 100mph, the computer makes it shift at WOT at about 88mph, waaay short of redline.. First time out I let it shift auto and went 14.3 @98, form then on out I used the TapShift and never ran a 14 again, ran a dozen or more 13.7-13.8's with a best of 13.6 @102.. IMO the order of the SS's is like this stock for stock, average driver.... from what I've seen at the track I am sure there are differing opinions, just how I've seen it play out so far..
1)2WD TBSS
2)AWD TBSS
3)ImpalaSS (LS4 5.3)
4)SC/SS
2-4 can be interchangable depending on driver, especially 3 & 4..
here's the slip from the 13.6 run..
here's a couple 1st time outs with my BONESTOCK at the time TBSS...
the TBSS has NEVER made a 14 second pass... which still amazes me till this day..
1)2WD TBSS
2)AWD TBSS
4)SC/SS
#47
go do some resaarch and see how many guys couldn't break into the 13's stock with their SS's... it's just pretty funny how every Magazine list the truck as a 14.2-14.3 @98 or so and my first ever run was a 13.55 @102 and an AWD went 13.9 @100.. goes to show you NOT to believe what they write about, go out and run your own car, guessing does nothing, or going by other's times... you need your own to know what the deal is..
#49
new stock Vettes are running between 112-115 stock, that weight and aero drag is HUGE... even with 4.10 gears look at the drop in MPH... I wasn't satisfied with my truck until I can firmly take on a new C6 at the track (w/o losing any DD characteristics)
#50
