War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
V6 Mustang vs V8 Camaro vs L4 Cobalt SS vs L4 Civic
Old 08-09-2005 | 01:12 PM
Blainestang's Avatar
Originally Posted by chadder
that seems sad to me that you had a blower and only put down 248rwhp...our blower guys with prochargers and powerdynes are puttin down nearly 300rwhp...which is a 13sec car EASY. And sorry to break it to ya...it obviously doesnt even take an internal modification to run 13's in a v6 f-body... (a little weight reduction and lots of gear will go 13's)
You guys are all stuck up on HP!! Hp sells, tq wins races, and the 3.8's make LOTS of torque...yeah sure we only get 200 flywheel hp, but we also get 220 flywheel torque, which raises much more with boltons, and skyrockets with a cam.
oh and i agree with your last statement blainestang.
I think there should be some clarification here.
1. 248whp is rather low for a Procharged Split-Port car (99-04) as many of them (~11psi) are making closer to ~300whp w/ a good tune... but we currently don't know much about PHXSS's setup, how much boost he was running, what other mods he had, and what kind of tune he had... this can all have a huge effect on whp, as we all know.
2. No one that I have heard of has ever tried the same method as "Little G" has (not a 'little' but a LOT of weight reduction) with a Mustang, so I can't say what one would run. It is, however, very impressive. BTW, how much does that car weigh?
3. I think we need to reitterate that the V6 Camaro running 13.0@~105mph has Gears, LSD, Cam, and FULL BOLT-ONS. This I believe is possible w/ a very well-matched and tuned setup. For reference, there is a 3.8L Mustang w/ similar mods and heads that is in the low 12's last time I checked.
4. I will certainly agree that one needs to consider tq when determining how fast a car could/should be. Tq often gives a good indication of a cars powerband. A car with a lot of tq generally has a wider powerband, but cars can still be fast w/o tq, because rpm's can build hp w/o it... as the S2000, Type-S, etc. have shown. HP is important, TQ is important, and Powerband is important... but one w/o the other 2 don't tell you the whole story.
BTW, I agree w/ my last statement, too I am so tired of people having ignorant opinions of cars just because they don't know jack about them. You'd think someone who drove a Cobalt SS would feel the same way as I know they get the same kind of crap from people who say "it's a glorified Cavalier" and other ignorant stuff, but I guess some of them still like to be ignorant.
*Disclaimer: Not all Cobalt SS owners are like that, I know, because I know of many level-headed owners on this board alone
Old 08-09-2005 | 03:05 PM
chadder's Avatar
i think Little G's car weighs in around 3k lbs racewieght, im not fully sure what all he has taken out/replaced...so dont ask... I believe his car, without all the wieght reduction, will run around a 14.1-14.3, so weight is quite a factor here!
Blainestang, we PWND!!
Old 08-09-2005 | 07:33 PM
codyss's Avatar
A) A 1990-1992 Camaro IROC or Z28 with the 350TPI w/auto or 305TPI HO w/5-speed can easily run low 14's.
B) That cammed Firebird V6 running 13's sure. Did they have to split the block to fit the lobes in?
Whats the exhaust sound like? Whup, Whup, Whup, Whup........................
Old 08-09-2005 | 07:53 PM
phxSS's Avatar
Chadder...my v6 stang did have 274whp initially, but it was running pretty lean, and also I had a vortech on it, and non-intercooled. With a procharger, it probably would be possible to have 300whp, but it would take some good tuning skills to pull it off SAFELY. When you have an intake temp. of 175 degrees, it's hard to produce a ton of hp. Also, even though I had a 9# pulley, I was usually only getting 5-7lbs of boost. Anywyas, back on topic. I still don't believe your car can run a 13 flat with only a cam add LSD. Unless, like I stated above, you have a completely gutted, to the bone interior.
Old 08-10-2005 | 12:01 AM
You do realize you can regrind the cam and get huge lift w/o having a greater maximum diameter, right? But that's not the point. The guy has ALL THE BOLT-ONS as well as Gears/T-loc, probably a little weight reduction, AND THE CAM. I still think the trap might be a bit high, but it's totally possible. There's a similar 3.8L Mustang w/ heads also that's running deep into the 12's. Sure it might have a lope at idle, but who cares? I'll take deep 13's from an N/A 3.8L w/ a little lope at idle anyday.
And, yeah, 248whp on a non-intercooled 5-7psi w/ a safe tune isn't bad. Of course it's always the best numbers for a specific car that everyone quotes, average certainly isn't ~300whp for a similar setup... more like for an intercooled ~11psi kit.
Old 08-10-2005 | 01:43 AM
xonic's Avatar
Originally Posted by Blainestang
OK, well that made no sense. You act like that would be impressive for those other cars, but not for the Camaro? Just because there are much FASTER Camaro's doesn't make it any less impressive to go from 15's to 13's N/A. Also, while the Camaro/Mustang V6's aren't in the same automotive class (Pony Cars vs. Economy Cars), they are certainly in the same PRICE class. I bought my 2000 V6 Mustang w/ just a couple thousand miles on it for $13k and over the last few years, the V6 Mustangs have been selling for ~$13k BRAND NEW. That throws it right in there w/ the other cars you mentioned... and guess what? It's one of the fastest, if not THE fastest of the cars in that price range. So, like the Cobalt SS, it may not be that fast compared to other Camaro's or Mustangs or whatever, but also like the Cobalt SS, it is a relatively fast car FOR THE MONEY.
I was trying to say that stock it's in the same class as those cars. I know they can be modded pretty well (from 15's to 13's). As far as being the fastest...it depends. I know the auto v6 mustangs are dogs (pre-05).
Old 08-10-2005 | 01:56 AM
VaMP's Avatar
Stock yes, only 165hp from the factory, but I've read about a 10 second NA V6 Mustang. The same one that is mentioned in the race is going to install an M112....
Old 08-10-2005 | 02:45 AM
phxSS's Avatar
AAhhhh, ok. So he has a shitload of mods to his car. In that case, it's believable to hit low 13's. i thought this guy just had a cam, and lsd.
Old 08-10-2005 | 03:13 AM
chadder's Avatar
nah, the 13 sec. bird has no weight reduction. And he doesnt have shitloads of mods to his car...(didnt anyways, it was sold..) It was an A4, FULL BOLTONS, 3.42 gears, a LSD, 3800 stall TC, a CAM, and a tune with HPTuners...thats really not alot compared to MANY guys out there with turbo/c/h setups etc...
and boltons only count for around 15rwhp....but I guess that is multiplyed with tune and cam...
Everything probably cost the guy; ~330 for the cam, 180 for gears, 300 for LSD, 300 for the TC, 500 for HPTuners, and around a grand for intake/exhaust (f-body stuff is cheap and 2000+ v6's come with tubular exhaust manifolds, which the crappy short tube headers are no better than...so headers is hardly a mod for 2000+ cars, and this is a 2000 firebird).
so a 13 sec v6 for 2310 (my best estimate, not including labor)...thats not too shabby.
Oh, and yeah, it lopes like a bigass v8. Sounds AWESOME!
Old 08-10-2005 | 03:20 AM
chadder's Avatar
oh, and currently, the fastest run of a v6 f-body was Shirl, from NJ, who ran a 11.87@110 (somewhere around there....LOL)
there are plenty of faster v6 f-body's out there, just none of them have been to the track and have completely finished thier cars, yet
Old 08-10-2005 | 09:39 AM
  #36
Yeah, it's in the same price class, like I said, but not too many of them could go low 15's like a manual V6 Mustang or Camaro could.
BTW, you're right, the Auto's were much slower, but you've got to compare apples to apples... and the auto Civics, Cobalts, and Corollas aren't what I'd call speed demons, either
Actually, the 94-98's had 145-150hp and the 99-04's had 190-193hp. Also, I've never heard of a 10-second N/A V6 Mustang, but that doesn't mean it doesn't exist. The best I've heard is low 12's N/A, though.
BTW, w/ regard to the 13-second Firebird, the trap does seem a bit high for the mods, which I can't imagine putting him over 250whp, but weirder things have happened. The ET, though sounds feasible for that amount of power and an excellent launch.
Rayray2781@gmail.com
09-20-2015 02:52 PM
Sean Cummings
09-11-2015 10:35 PM
Bluelightning
09-08-2015 06:18 PM
jthwjde
09-07-2015 10:24 AM
