Fitment of 17x7.5 +38 offset and 235/45ZR17 Tires
Hello everyone, I've been doing a lot of reading on these forums but couldn't find a thread that had this combination.
My question is, will I rub with this setup with stock 2006 Cobalt SS S/C FE5 Suspension? AND Will it rub when I eventually buy ZZP Lowering Springs? Also, any input about if the offset here helps out the fact that 235 is quite the width for a 7.5 inch rim.
Rims: NS Series NS1507
17" x 7.5", +38 Offset, 5x110 Bolt Pattern, 73.1mm Hub
Tires
235/45ZR17
Thanks for any input!
Tires
235/45ZR17
Last edited by xderekxhuggiesx; 03-01-2017 at 01:46 AM. Reason: Add more fitment information. (Offset with a wide tire and narrow rim)
