NEW! Gunmetal Chrome SS Stockers
I found out that Keystone charged the dealership more for the wheels since it was a warranty issue...
for those looking into these wheels as a NON-WARRANTY INQUIERY:
$165/per wheel....also...on the pics above, I do not have my centercaps coated...this is an option, I'm having them done as we speak...if you want this done, you will need to let the company know as well, otherwise you will get what I have ^ above.
Anyone interested either way, PM me and I will let you know how to get this done.
Hey since we're talking about rims and warranty with rim finishes, Cheryl, i had a question since you worked in Chevy before. i bought my car used and the person before had not taken care of his rims: therefore, curb rash and my polished finish faded, however, i am still under warranty, would chevy warranty me new rims?
Thanks!
-Francis
Thanks!
-Francis
Thanks!
-Francis
Thanks!
-Francis
Update!
Those of you who have contacted Keystone Automotive, you should be receiving your wheels soon...One of you were kind of waiting on me to switch out my old centercaps...Just put my new Gunmetal Chrome centercaps in last night when I put on my Baer Brake kit, so my old centercaps are getting sent out to get coated today. Im uploading pics to photobucket right now, I'll post them in here as well as my thread for the brake kit. Thanks for giving this company business, theres a few of you who have gone through with this process and I greatly appreciate it..you will not be let down..thanks for your patience, also!
#39
if nobody knows this, I will stop at the dealership I had this performed at where they have all my files and ask them to pull the service copy for me..I know I had a copy somewhere of the TSB but I don't know off hand where it is. I even posted this in an old thread on here, not sure if I included the TSB or not
#40
I LOVE my gun metal rims on my silver ss it blend well and dont call more attention than the car in self nobody say nice rims william, they say nice car and after that they ask me if i got turbo? lol i guess the intercooler trow ppl off!!! except this old Chevy guy who want to buy the damn rims lol.........
#42
Found It!!!!
Thanks for the rep points!!
I dug out my repair order, and since I dont have a scanner at the house here, I'll just type exactly what it says if anyone is interested...
problem was checked out on August 3, 2006 (10,624 miles at the time)
Warranty issue #1024 - Called tec, spoke with Larry Raymer..wheel chip and peel due to wheel design and low profile tire with wheel outside of tire...chip when on back wheels...advise cll dvm if replacement wheel desired also hear f dealer that stripped color and thn clear coated...much cleaner lok and chips not as noticeable. Which ever way chosen - 1 tie only repair and damage will happen again on next set of wheels Richard Service Manager eplained to customer and advised she has record of complaint and doesn't need to decide right away and can think about case#9096960.
Document/Bulletin ID# 1841203
2006 Chevrolet Cobalt
Info-Refinishing Aluminum Wheels #99-08-51-007C
This buletin updates GeneralMotor's position on refinishing aluminum wheels. GM doesnot endorse ay repairs that involvewelding, bending, straigtening, or re-machining. Only cosmetic refinihing of the wheel's coatings, using recommendd procedures, as allowed.
Evaluating Damage:
It is the GM Dealer's responsibility to inspet the wheel for corrosin, scrapes, gouges, etc. The dealer must insure that such damage is not deeper than what can be sanded or polished off. The wheel must be inspected for cracks. If cracks are found, discard the wheel. Any wheels with bent rim flanges must not be reaired or refinished. Wheels that have been refinished by an outside company must be returned to the same vehicle. The dealer mst record the wheel ID stamp or the cast plat on the wheel in order to assure this requirement.
Aluminum Wheel Refinishing Recommendations:
-Chrome-plated aluminum wheels- re-plating tese wheels is not recommended
-Polished aluminum wheels - these whels have a polyester or acrylic clearcoat on them. If the clearcoat is damaged, refinishing is possible. However, therequired refinishig process cannot be performed in the dealer environment.
-Painted Aluminum Wheels - These wheels are painted using a primer, color coat,and clearcoat procedure. If the paint is damaged, refinishing is possible. As with polishd wheels, all original coatings must be removed first. Media blasting is recommended. Refer to GM ALuminum Refinishing Bulletin #53-17-03A for repainting of this type of wheel.
-Bright, machined aluminum wheels - These wheels hve a polyester or acrylc clearcoat on them. In some caes, the recessed "pocket" areas of the wheel may be painted Surface refinishing is possible. The wheel must be totally tripped by media blasing or other suitable means. The wheel should be resurfaced by using a sanding process rather than a machining process. This allows the least amount of material to be removed.
IMPORTANT: Do not use any re-machining process that removes aluminum. This could affect the dimensions and function of the wheel.
Painting is an option to re-clearcoating polished and bright machined aluminum wheels. Paint will better mask any surface imperfections and is somewhat more durable that clearcoat alone. GM recommends using Corsican SILVER WAEQ9283 for a fine 'aluminum-like" look or Sparkle SILVER WA9967 for a very bright look. As an option, the body colo may also be used. When using any of the painting options, it is recommendedthat all four wheels be refinished in order to aintain color uniformity. Refer to GM Aluminum Refinishing Bulletin #53-1-03A for specific procedures and product recommendations.
__________________
Evaluating Damage:
__________________
#45
I used to work for a Chevrolet dealership, and my father is the Assistant Service Manager at the same dealership I worked for, so I know exactly how warranty works and OUR WHEELS ARE COVERED.....print out the bulletin I pasted above in case the dealership tries to give you a hard time.
#47
yes sir...its actually a really simple process...you actually dont send your car to Keystone...the service manager contacts Rick at Keystone and you get sent a new set of stockers re-finished to your liking at N/C to you or the dealership since it is a warranty issue (if you are still under warranty, that is)...the only thing you need to do is tell the service manager the information I provided you above, making sure they know it is NO EXTRA COST to them, GM Warranty covers it all...Rick Mazees will fully explain everything to them...then when the dealership receives your wheels, they will call you to schedule an appointment to get them mounted and balanced and you MUST do this at the dealership so it can be documented for GM in order for the dealership to get paid.
And theres one problem. I dropped my wheel lock key on my rim and it took of some paint and put a lil dent in it. Can that still be refinished?
#50
Is keystone the place they always use, even in north jersey or do i have to ask them to send the rims there? And do i tell the dealership wat kinda rims i want?
I don't have them fully broken in yet, but so far they are great! I love the appearance & performance of the brakes
Last edited by CobaltSSChick; 11-14-2007 at 04:47 PM. Reason: Automerged Doublepost
