New here...hub cap tsb
Hey Guys...i have been watching this site for a while and lots of good info...Thought I would contribute as I didnt find this anywhere.
I own a 2006 cobalt ls as base as it gets lol.
I found after about 4000kms i had a squeek coming from my wheels.Seems like GM cant get the hubcaps on tight enough.So if anyone has this problem, there is a bulletin on this and they put some anti-squeak tape on the hubcaps. I just took my hubcaps off. I can get the bulletin number if anyone is interested.
what? no base guys have ever had this problem before? it can`t be just me...I know the j-bodies had a lot of these problems. You can often hear them coming that the street with their wheels banging like crazy lol.
Here...show this to your dealer, they will fix it under warranty..
Document ID# 1844360
2006 Chevrolet Cobalt
Subject: Wheel Squeak (Install Wheel Cover Insulators) #05-03-10-006B - (06/27/2006)
Models: 2005-2007 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007 Pontiac G5
with 15-Inch Wheel Covers
This bulletin is being revised to add models and model years. Please discard Corporate Bulletin Number 05-03-10-006A (Section 03 -- Suspension).
Condition
Some customers may comment on a squeak type noise coming from the front or rear wheels. This condition is most apparent during cold weather and while driving at low speeds (0-24 km/h [0-15 mph]).
Cause
This condition may be caused by hard contact between the inner edge of the wheel cover and the outer edge of the steel rim.
Correction
Install insulator tape on the backside of all four wheel covers. Use the following procedure:
Chevrolet Cobalt/Pontiac G5
Pontiac Pursuit
Remove the wheel covers.
Clean the backside of each wheel cover using a mild liquid detergent in a distilled or deionized water solution. Rinse each wheel cover with clean water.
Dry each wheel cover using compressed air or a clean, lint-free, non-abrasive cloth.
After the wheel covers are completely dry, each wheel cover should be wiped with isopropyl alcohol (using a clean, lint-free, non-abrasive cloth) at the insulator locations. Refer to the illustrations above.
Cut forty 7 mm (0.275 in) lengths of *3M® Squeak Reduction Tape 5430, P/N 06356.
Peel the non-stick backing off tape.
Carefully place the tape (insulator) onto the wheel cover's backside at the outer most edge as shown in the illustrations above.
Press down firmly on the insulator to ensure that the adhesive is bonding to the wheel cover.
Repeat steps 6 through 8 with the remaining insulators. There should be 10 insulators placed on each wheel cover.
Important: Also, place an insulator onto the wheel cover's backside at the location of the clip-on wheel balance weight.
*We believe this source and their products to be reliable. There may be additional manufacturers of such material. General Motors does not endorse, indicate any preference for or assume any responsibility for the products from this firm or for any such items which may be available from other sources.
Parts Information
P/N
Description
Qty
Material Allowance
3M® 06356*
Length - 305 mm
(12 in)
$2.00 (U.S.)
$3.00 (Canada)
*To obtain this product, check your dealer's auto body shop - they may already have this tape. You may also contact the 3M® Automotive Aftermarket Helpline at 1-877-666-2277 and follow the menu options to locate a store near you where it can be purchased.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E0027
Cover, Wheel - Replace (All)
Use Published Labor Operation Time
In Other Labor Hours, add 0.5 hr for installing wheel cover insulators (authorization required).
2007 Pontiac G5
Condition
Cause
Correction
Pontiac Pursuit
Parts Information
P/N
Description
Qty
Material Allowance
3M® 06356*
Length - 305 mm
(12 in)
$2.00 (U.S.)
$3.00 (Canada)
Labor Operation
Description
Labor Time
E0027
soccerkid13
01-11-2016 10:25 AM
satisfied
10-19-2015 12:35 AM
Adam144
09-03-2015 07:48 PM
