Quick Question
Quick Question
I need some help. I changed my stock 15" wheels for 17" Giovanna and of course they didn't came with pressure sensors so the light on the cluster flashes and stays light up. Can I put on the OEM sensors from the stock to those new wheels or do i need to buy new ones? If so what are good suggestions?
You will want to check with the wheel manufacturer first to make sure the wheel was machined / designed to take a sensor. Not all wheels are, so do a little research to be on the safe side
