Show off your aftermarket wheels.
#3052
#3054
#3058
#3060
I think your specs are a little off dude! That thing is poking like a **** and the only info I can find as far as size on the wheel are 8.5/9.5 with the rear offsets being +45 or+22. None the less a solid color scheme and some sexy wheels.
**just found the 8/9" +35et staggered sets, even more confused how you're poking as much even being +16 in the rear.
#3062
This. Running adapters because you cannot do a hub swap to 5x120. Not enough room on the hub to have it drilled out to 5x120. You can do the rotor, but definitely not the hub. Adapters are from Motorsport Tech in Nevada. $280/4
Here are the specs:
CSL Reps 18x8 and 18x9 +35
Front adapters are 31mm and rear are 19mm. Only did this because the set was staggered.
Here are the specs:
#3063
Here are the specs:
Here are the specs:
#3064
Nah, it's poking a good bit man. lol. I'm happy with it!
#3066
#3068
I wouldn't want mine poking that much those. I would prefer mine as close to flush as possible.
Yours looks amazing though. We need some pics in the day light!
