Show off your aftermarket wheels.
Old 11-23-2009 | 04:44 AM
  #1351
ff_drift_lol's Avatar
for caster you mean? there's no rear axle. you can't adjust anything in the rear. everything's fixed.
Old 11-23-2009 | 12:53 PM
  #1352
Cobaltsky05's Avatar
everything is fixed but you can still adjust it.. you have to use shims but you can..
Old 11-23-2009 | 01:01 PM
  #1353
FASTL61's Avatar
hhahaha
Old 11-23-2009 | 01:22 PM
  #1354
ls1fbody's Avatar
Haz l33t wheelz.
you obviously know nothing about my rear axle...
i can adjust camber and toe. Also, if you loosen the two brackets that hold the axle to the car, you can move it a little side to side etc.
thats not a good idea on the stock rear TWB. the mounting provisions for the wheel bearings are really weak.
Old 11-23-2009 | 01:24 PM
  #1355
dman090's Avatar
i see you taking **** about your ksport coilovers all the time, are they really that bad of a coilover?
i was looking into buying some, should i steer away from them? i mean im not gonna put my car through hard core turns and **** like you will be, im just looking for a replacement for my sportlines/SS/SC FE5's
Old 11-23-2009 | 01:28 PM
  #1356
ls1fbody's Avatar
Haz l33t wheelz.
in your case i would got with ss/tc struts and pedders springs. its not so much that they're shitty, i love the front setup, and they ride great. they just take a lot of maintenance, and the rear setup with the time attack axle is fail.
Old 11-23-2009 | 01:38 PM
  #1357
dman090's Avatar
well see, im not wanting to sacrifice the drop, im not to fond of the drop of the pedders springs. im looking at buying a ksport set up of a member on here for 425 shipped. i just want something that rides smoother than my sportlines and FE5's with out sacrificing ride height
Old 11-23-2009 | 01:40 PM
  #1358
ls1fbody's Avatar
Haz l33t wheelz.
the front you can adjust to ride nicely. the rear is kinda a bummer, cuz the shock is not adjustable. IT kinda rides like a truck, in that on the freeway it gets a little bouncy. I would suggest using the coil and perch for the rear, and using your stock shock.
Old 11-23-2009 | 01:42 PM
  #1359
didn't say it was the best idea if you slammed into a curb pulling the ebrake but if your out just a small amount it's not going to make that big of a difference either way.
Old 11-23-2009 | 01:44 PM
  #1360
dman090's Avatar
thats pretty much waht im gonna have to do cause his rear shocks 1 is blown and the other isnt rebounding correctly( or so he says)
you dont think the stock rear shock would be to long to fit? or they both the ksport and stock shock the same size?
Old 11-23-2009 | 01:49 PM
  #1361
ls1fbody's Avatar
Haz l33t wheelz.
it'll be fine, you can take the spring out and let the car fall down onto the bump stops ad it still won't bottom out the shock.
Old 11-23-2009 | 01:54 PM
  #1362
USMCFieldMP's Avatar
Rattlesnake Race Shop
Damn Will... that looks damn good!
Got me considering a black/CF hood/trunk too.
Old 11-23-2009 | 01:57 PM
  #1363
ls1fbody's Avatar
Haz l33t wheelz.
i wanna do the hood and roof as well. the roof may just end up being black vinyl. nothing permanent.
Old 11-23-2009 | 02:03 PM
  #1364
spike's Avatar
i would die for something kinda like that but with dry carbon hood and trunk and a dupont hot rod black painted roof
Old 11-23-2009 | 02:09 PM
  #1365
What is your trunk? Black paint/vinyl or CF?
I've never really been a big fan of that look on our cars, but I'm loving it in that picture. I'm picky with my cars.
Old 11-23-2009 | 03:14 PM
  #1366
ls1fbody's Avatar
Haz l33t wheelz.
The truck is a Crawford Composites CF. Same trunk that was on the Time Attack cars.
Old 11-23-2009 | 03:32 PM
  #1367
there is no rear axle. maybe your setup since you ****** rigged everything for your cheapo wheels.
Old 11-23-2009 | 06:11 PM
  #1368
dman090's Avatar
ok good. thanks for the help
Old 11-25-2009 | 04:42 PM
  #1369
Micro's Avatar
Originally Posted by BaltM62
Wheels: Rota Subzeros 17inch (17 lbs a piece)
Tires: Fuzion ZRi's 235/45/17
Drop: H&R Springs
I like the stance of your car with the H&R Springs and the 17 inch wheels. Great choice. I may copy you!
Old 11-25-2009 | 04:49 PM
  #1370
philipino guy's Avatar
msr 044's
dropped on sportlines
Old 11-25-2009 | 04:59 PM
  #1371
Micro's Avatar
Originally Posted by 2K5SS/SC?
Everyone's probably seen these pics before, but here they are again!
17" Rota Subzeros 5x110 w/ 38mm offset (Custom One Off Run of 8-10 Sets Made)
235/45/17 Toyo T1R's
SSC Springs
This tire/wheel setup saved me 10lbs on each corner for a total of 40lbs shaved!
Awesome looking wheels. I would love to have these. Too bad they were a limited production run.
Old 11-25-2009 | 05:26 PM
  #1372
sorta like those wheels too. they look like the enkei's on the time attack car. good choice of tires for those wheels too. I really wish our bolt pattern didn't suck I am dying for work emotion knockoffs.
Old 11-26-2009 | 10:26 AM
  #1373
SilverSS/SC's Avatar
Here a old pics of my SS with the Rota subzeros
... and a pic of a Berger SS with Fikse profile 5 wheels .
Old 11-26-2009 | 10:33 AM
  #1374
Black SS/SC 06's Avatar
What is a Berger SS?
Old 11-26-2009 | 10:35 AM
  #1375
freakta's Avatar
Originally Posted by Chinelli3589
i want these soo bad, anyone know if they make a similar wheel that fits?
Quick Reply: Show off your aftermarket wheels.
