Stock Tire Pressure?
Old 05-10-2015 | 07:16 PM
SnowPawsFox's Avatar
Exclamation Stock Tire Pressure?
What's the stock tire pressure for the 2008 model year Chevrolet Cobalt LS Sedan? It has the stock wheels. The sticker on the door that has the pressure wore off, and the manual doesn't seem to say. Thanks in advance!
Old 05-10-2015 | 08:10 PM
Superbolt's Avatar
It's on the tire.
Old 05-10-2015 | 08:20 PM
Mr.Tozzi's Avatar
what's on the tire is the maximum pressure that the tire can take.
your recommended pressure should be on the drivers door jam under the door latch.
should be 30psi if you got 15" tires and I believe 16" and 17" is 35psi
Old 05-10-2015 | 08:23 PM
LTBALTBMX's Avatar
I dont have it handy but try checking the manual
Old 05-10-2015 | 08:29 PM
Grave's Avatar
Originally Posted by Superbolt
It's on the tire.
No
He said the sticker has worn off, but probably 32.
He said it wasn't in the manual.
Old 05-11-2015 | 07:38 PM
It's on the tire.
That appears to be the maximum pressure. I'm looking for the stock pressure for the LS' tires.
Old 05-11-2015 | 07:41 PM
I saw 33psi but that was an SS model and coupe, so maybe 35psi sounds like a good number to have them at
Old 05-11-2015 | 07:46 PM
Thank you for the reply! But the sticker has since worn away, now it just looks blank!
Old 05-11-2015 | 07:49 PM
Also, the stock steel wheels w/ stock hubs are 15" right?
Old 05-13-2015 | 07:43 AM
doc@tirerack's Avatar
Supporting Vendor
195/60R15 should be at 30 PSi (cold) front and rear axles
05-28-2022 03:47 AM
bigdeertz
11-17-2016 09:41 AM
RaginChopsuey
10-27-2015 01:27 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
DANRICKARD
10-01-2015 12:08 AM
Quick Reply: Stock Tire Pressure?
