Tire Relearn
Tire Relearn
ok, i just put on my enkei's with BFG KDW2's and its throwin the tire pressure warning light. i think all i have to do is do the tire relearn? can someone explain that
you have to get into learn mode (same are on the DIC where you would reset oil life, change language, change units, etc) go to tire learn. Start at one tire and let air out til the car honks at you (thats the car recognizing what tire your at) then fill it back up (may honk again when done with that tire) then move on to the next tire and keep going til you do all four.
^thats what i think you do off the top of my head, not sure exactly though. like i said its in the manual
1. activate learn mode (either DIC or with key in the on position hold both lock and unlock buttons on keyless remote
2. start letting air out at driver side front tire and work in a clockwise sequence, after each tire u should hear a confirmation honk
3. once the final tire is learned u should hear one or two confimation honks that tells u it was successful
4. fill tires back up
thats how we do it at my work except we got a new tpms tool that makes it way easier
agentirons
10-16-2015 02:11 AM
DANRICKARD
10-01-2015 12:08 AM
