What about these
What about these
Read the rating but not sure what to think. I got confused with the tread wear rating. Is a higher number good? or is it lower? Well i know im going to get flamed but i dont want to spend more on tires then i do on rims.
Exclaim
The general exclaim uhp tire has an Innovative double-V pattern for enhanced wet traction .Wide, solid shoulder lugs and high-tech contour for precise handling. Optimized silica compound for excellent all-weather traction.
UTQG Rating
Treadwear Traction Temperature
380 AA A
from tire savings dot com
if you search on tire rack for 225/35/19s they are the first set. Look pretty decent. Let me know what yall think.
Exclaim
UTQG Rating
380 AA A
Higher number for treadwear = tires will last longer. FYI the treadwear for the short-lived stock Pirellis is 200...if you want to use that as a reference point.
