What tire size "looks" better
Old 08-15-2008 | 09:48 PM
MBMCustoms's Avatar
I am getting some wheels and they are 18 by 7.5s and i have been looking at tire choices and want to know what size looks the best if i want to keep the lowest profile possible.
215/40/18
-or-
225/40/18
Old 08-15-2008 | 09:49 PM
dman090's Avatar
i say 225/40/18
Old 08-15-2008 | 09:50 PM
MBMCustoms's Avatar
so whats the difference in the two sizes???
Old 08-15-2008 | 09:51 PM
dman090's Avatar
225 is gonna be a lil bit wider than 215
225= width
40= side wall(ex low profile)
18 = the size rim it fits
i think the width and side wall is measured in MM but im not sure
Old 08-15-2008 | 09:53 PM
WhiteSSBalt's Avatar
Not a Sebring
Well I have 225's on my 8" wide wheels and they are pretty much stretched, so I say 225.
Old 08-15-2008 | 09:54 PM
MBMCustoms's Avatar
ok thanks. if anyone else could give me some pointers, all is welcome
Old 08-15-2008 | 09:55 PM
thought's Avatar
Width is MM, sidewall is percentage of the width. So if you go wider, you will need a smaller sidewall percentage to keep the overall diameter the same.
Old 08-15-2008 | 11:14 PM
06SS/SC STAGE2's Avatar
Here man- http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Read and you will see the differance. I would say 225/45/18. 225/40/18 would be a little small, 225/45/18 would be closer to the stock size. You want to be with in +/- 3% of the stock size. Closer is better. 235/40/18 is closest but some can run them w/o rubing and some cant. If you plan on lowering your ride or if its already lowered 225/45/18 would fit just fine and give you a little more rubber on the road.
Old 08-16-2008 | 02:13 AM
MBMCustoms's Avatar
ok i have made my decision to go with the 225/40/18. thanks for the help.
Old 08-16-2008 | 02:15 AM
Raven SS's Avatar
wow this thread fails..never thought i would see people worry about what there tire looks like...how about worrying how it performs?
Old 08-16-2008 | 02:19 AM
MBMCustoms's Avatar
im sure they will perform about the same... unless you want to talk about the drag radials i want to throw on some 17s.
Old 08-16-2008 | 02:20 AM
ItalianJoe1's Avatar
Get a 235/40 minimum, I ran them on stock rims (18x7) and they barely were wider, 225/40's aren't wide enough for a 7.5" rim.
Old 08-16-2008 | 02:21 AM
MBMCustoms's Avatar
Thanks!
Old 08-16-2008 | 08:23 AM
But on 235/40 18's and being lowered it wont happen. You will rub. Most on here I have seen and read about rub at stock height from one drgree to an other. If you drive your car agressive on a hard turning road you will rub. Wether is strut or fender rub. Why run the risk, Up to you. But 225 45 18's is as far as I would go. Also consider the more mass you put on the wheel the more stress you put on that wheel and breaking system. Just my .02
Old 08-17-2008 | 02:27 AM
MBMCustoms's Avatar
thanks. i am still sticking with the 225/40/18
Old 08-17-2008 | 08:37 AM
225/40/18 are even smaller than the 225/45/18's. Look on that link I posted and you will see just how much smaller.
Old 08-17-2008 | 08:10 PM
I'm on Eibachs, no rubbing, and I drive the car HARD. There was a little rub mark on the inner fender of the drivers side, but it was almost nothing, just occasinal contact when leaning hard on the car, does not rub for me under normal conditions. I was running KDWs if it matters, some manufacturers measure differently, the KDWs have a huge shoulder, so if they cleared anything should. Just my personal experience.
Old 08-17-2008 | 09:37 PM
_UnLiMiTeD_'s Avatar
theres peoples runnin 19's lowered with no issues, 235 and 18\s are fine
Old 08-17-2008 | 10:02 PM
Id have to see it. Would love to run 235/40/18's on lowered with sportlines. Would realy need to see pics of tire gap an fender front and rear, also clearance between tire and strut.
Old 08-17-2008 | 10:33 PM
I don't have any pictures of it anymore, and I went to a different tire last time to save money so I can't give current pictures, but it fit fine, looked great, really looked beefy and filled out the wheel wells more, looked perfect. I got compliments from my car buddies about how good it looked with the bigger tires on there and the drop. I'm going back on 235/40 KDWs when I change tires again, as long as I keep the 18" wheels.
Old 08-18-2008 | 02:23 AM
kkanowitz's Avatar
Exactly....I'm also running 235/40/18 on 7.5" lowered on Sportlines. Just that little tiny spot Joe mentioned but you don't even notice it unless you search for it. I've never heard it either.
Old 08-18-2008 | 06:27 AM
maverick0716's Avatar
lol, 225 is literally the perfect width for a 7.5" wide wheel. I've worked in the tire industry for 7 years, and I've mounted countless tire/wheel combos. Hell, even the new SS/TC with 7.5" wide wheels has 225/40R18 tires. I guess if you want the tread of the tire to bulge past the lip of the wheel a little bit, 235's are fine, but 225's are definitely the perfect fit for 7.5".
Old 08-18-2008 | 07:38 AM
That does look good and from all the numbers I looked at it is a smaller tire, except for the width (of course). So I dont see why they wouldnt fet well.
I too agree with you. But I think the 08/09 ss/tc has 8" wide wheels. In either case. From looking at the pics above it dosnt seem that the sidewall is bulging past the edge of the wheel.
Old 08-18-2008 | 02:26 PM
The SS/TC has 7.5" wheels for sure. But anyway, yes the 235 won't bulge a ton or anything, and will still look good.
Old 08-18-2008 | 09:12 PM
Im just torn on the 2 sizes. According to the tire sizing link I posted the 235's are only an 1" wider. If you divide that by 2 its then a 1/2" per side of each tire. The overall diameter and height is smaller. So according to the numbers I understand that the shouldnt rub. But any rub to me is not good. On my 04GTO tire/strut rub is the norm from the factory. And I hate it. (exwife drives that car).
Hey Kanowitz could you take a closer pic of the tire/fender to see the gap?
