What tire size "looks" better
Old 08-18-2008 | 09:15 PM
britt's Avatar
i have 235/40/18's
there's no rub or anything.
but i dont have it lowered either.
IMO they look good
occsdude's Avatar
Originally Posted by dman090
225 is gonna be a lil bit wider than 215
225= width
40= side wall(ex low profile)
18 = the size rim it fits
i think the width and side wall is measured in MM but im not sure
but the side wall measure is a percentage of the width
Old 08-18-2008 | 09:27 PM
06SS/SC STAGE2's Avatar
Correct. stock 215/45 are 8.46" wide and side wall (45%) is 3.80" tall Now 235/40's are 9.25" wide and side wall (40%) is 3.70" tall. So the numbers say it will fit. Id still like to see a close up of 235/40/18's and the fender.
Old 08-19-2008 | 04:12 AM
kkanowitz's Avatar
Originally Posted by 06SS/SC STAGE2
Im just torn on the 2 sizes. According to the tire sizing link I posted the 235's are only an 1" wider. If you divide that by 2 its then a 1/2" per side of each tire. The overall diameter and height is smaller. So according to the numbers I understand that the shouldnt rub. But any rub to me is not good. On my 04GTO tire/strut rub is the norm from the factory. And I hate it. (exwife drives that car).
Hey Kanowitz could you take a closer pic of the tire/fender to see the gap?
I'm almost positive that there is not tire/strut rub. If you want an additional opinion/proof, my buddy Fallen33 on here is running the same setup as me (same tires/springs) with the addition of Koni struts.
These are some brighter pics, but I'll try an snap a close up tomorrow after work for you.
Old 08-19-2008 | 07:33 AM
Yeah if you could take some closer pic that would be great. Im getting ready to buy sportlines and then want to go with wider tires. But trying to decide.
Old 08-19-2008 | 12:47 PM
kkanowitz's Avatar
No prob....I'm heading to work now....It'll be later tonight.
Old 08-19-2008 | 01:52 PM
EmperorJJ1's Avatar
the 215 will be the lower profile if that's what your asking. the sidewall height is a % like stated above so wider tire means taller sidewall even on the same number
and i have 235/40/18s and they do rub on H&Rs... I've herd similar stories with other springs as well so if you hate rub then 235 isn't the way to go. 225 is the widest that's recommended for our cars
Old 08-19-2008 | 02:02 PM
Video2402's Avatar
235's Woot !
Old 08-19-2008 | 09:04 PM
This is what I posted yesterday.
215's are 3.80" tall, 235's are 3.70" tall. 100 thousands smaller than the stock. I think where folks are getting the rub is under braking/hard turning on the rear portion of the fender skirt.
Im still debating.
Old 08-19-2008 | 11:23 PM
EmperorJJ1's Avatar
lets put it this way. i have 235/40/18 nittos and my fenders are rolled... the kicker is i never rolled them and bought the car off the lot.
i dont think height is the issues its the width. skinner tires can go into the wheel well. wider ones hit
Old 08-19-2008 | 11:25 PM
  #36
OrngBalt's Avatar
I just got 225/40/18 and they look fanfuckingtastic
Old 08-20-2008 | 03:29 PM
  #37
EvlPeanut's Avatar
x2.. same here..
Old 08-20-2008 | 10:18 PM
  #38
Anyone have close up pics of an SS lowered on sportlines with 225/40/18's. They are a little smaller than the stockers in diameter and circumference and throw the speedo off 1.2 mph. Just want to see how thay look. I have given up on the 235's and that leaves me 225/45's or 225/40's.
Old 08-20-2008 | 11:59 PM
  #39
BMC2U's Avatar
235/40-18 on an 18x8 w/45mm backspacing.
Old 08-21-2008 | 10:59 PM
  #40
Those look good BM, but Id like to see a close up of a Balt rolling on 225/40/18's and lowered. As I said in my above post the 225/40/18's are a little smaller than stock in heigth and diameter. Which one apperance wise means more fender gap, even lowered (possably) and the smaller tire means speedo will be off. I know on this thread- https://www.cobaltss.net/forums/wheels-tires-96/tire-question-120442/
and post #4 is a pic of a Balt on 225/45/18's lowered and it looks good, but Id also like to see some 225/40's lowered.
Here you go guy's. A Balt TC, they come stock with 225/40/18's. First pic is stock, and rest are lowered on Sportlines.
https://www.cobaltss.net/forums/suspension-67/new-suspension-ss-tc-126508/
I think I just found my set up. Fender gap looks good and Im sure with the decreased side wall and lowering, the handling will be greatly improved. Now I just need my pay check!
Last edited by 06SS/SC STAGE2; 08-21-2008 at 11:00 PM. Reason: Automerged Doublepost
bigdeertz
11-17-2016 10:41 AM
10-13-2015 10:32 PM
DANRICKARD
10-01-2015 01:08 AM
nathan112i
09-30-2015 08:12 PM
09-26-2015 07:44 PM
