ZZ Performance ZZ Performance is a proud Supporting Vendor
07 Cobalt ZZP 3" CAI
Old 08-14-2010 | 08:17 AM
100% METH's Avatar
Everything came as listed on their website
Wrinkle black is def. a nice alternative to a stockish look
Clears the 07 brake lines...(barely)
Was a major pain to install due to a super tight fitment. WD-40 is your friend!
OEM MAF sensor screws work w/ provided maf housing.
Over all it's a quality product
Old 08-16-2010 | 12:31 PM
Zooomer's Avatar
Supporting Vendor
Glad to hear, thanks!
Old 08-16-2010 | 12:33 PM
Phyrric's Avatar
Sweetness, will be getting one after Stage2, are 07s the only ones with the brake line issues?
Old 08-16-2010 | 03:03 PM
100% METH's Avatar
I think so
Just take your time w/ it and lightly lube up the cuppler for ease of install.
Old 08-20-2010 | 01:18 PM
dspeed123's Avatar
Your MAF bolts worked? Hmmmmm..... maybe mine were not original then. Looks like some type of metric thread bolt and the ones that were on my car were some strange course thread deal.
Old 08-21-2010 | 04:33 PM
100% METH's Avatar
possibly?
they threaded right in tho...
I do recall fudging around w/ a 3" maf housing from ZZP and the OEM screws did not fit.
Old 08-21-2010 | 09:47 PM
jrzdude's Avatar
I'm having an issue with mine...The coupler with the bend in it is being squished by the coolant reservoir and the frame. Am I just installing it wrong or what?
Old 08-21-2010 | 09:59 PM
100% METH's Avatar
Try turning the coupler
- attach the maf side first
- then rotate the coupler until it clears
- attach throttle body side
- check for clearance issues, and tighten
TedSS
101
04-25-2016 11:46 PM
OrngBalt
09-16-2015 08:45 PM
medic710
09-06-2015 09:53 PM
CobaltSS 16
09-06-2015 03:04 PM
