2.3 stroker
2.3 stroker
When will the 2.3 be available for purchase?
How much power will it be able to hold?
Is it a direct bolt in replacement? LSJ or LNF?
Is there any sort of base tune available with the motor?
Does the motor include an intake manifold?
Is there any warantee?
Yes on warranty but we haven't decided on specifics.
Yes on direct bolt in. The engine doesn't require a tune. Everything will work the exact same as your motor now. Just take out the 2.0 and install the 2.3. All your existing parts bolt up and the tune doesn't really change. Boost will drop by approx 4 pounds at same pulley size.
We will not be asking for original blocks back unless you are buying one for the LNF. We will have a trade in program to save people $ most likely.
Bump! I saw you were developing this on the website... will it work for the LNF? Considering we only have Wiseco pistons available thus far (not sure how much you bore the block out...) Also, how do you think it will mess with the DI?
I'll test it for ya though
