ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 07-02-2015 | 04:52 PM
  #301
Originally Posted by KMO43
At around 1500ft at 0% wgdc I would hit 32psi on the high boost
What was your preload?
Old 07-02-2015 | 05:51 PM
  #302
KMO43's Avatar
Not very much because I knew it was the high boost actuator I'm running way more now that's why I'm thinking of switching
Old 07-02-2015 | 07:45 PM
  #303
It should of started cracking around 17psi with 0wgdc
Old 07-02-2015 | 10:19 PM
  #304
Terminator2's Avatar
The air density is normally above 6000'
not to mention all that legal weed making things high as hell (couldn't resist it)
. Now if they would re legalize anabolics I would be happy. The stoners get their weed and we bodybuilders get our gear If any states ever do I am moving immediately
Old 07-05-2015 | 08:01 PM
  #305
mh167002's Avatar
Results
Hopefully the links work.....
I was able to get some images of my dyno results from friday.
One image is with both the catless downpipe (2) and with the spun metal downpipe (1) and the other is just the catless downpipe.
So maximum power is at 387hp and 369tq with the catless downpipe.
My mods are:
Stock motor top to bottom
Hahn intercooler
Hahn upper charge pipe
Hahn spun metal catted downpipe (catless on order)
Stock cat back with muffler
ZZP lower charge pipe
K&N SRI
7163 ZFR
F40 swap
Old 07-05-2015 | 08:21 PM
  #306
09CobaltSS1's Avatar
Those are some pretty beat numbers for that 24-25psi tune you're running there.
My mods are:
Hahn intercooler
K&N SRI
7163 ZFR
F40 swap
Old 07-05-2015 | 08:51 PM
  #307
mh167002's Avatar
09CobaltSS1 I'm not sure how to take that. Lol. Is "beat" good or bad?
Old 07-05-2015 | 10:02 PM
  #308
They strike me as a tad low to be perfectly honest. I know it's a mustang dyno and all but, I certainly expected a bit more.
Old 07-06-2015 | 12:57 AM
  #309
LNFwagonSS's Avatar
My mods are:
Hahn intercooler
K&N SRI
7163 ZFR
F40 swap
Fuel?
Old 07-06-2015 | 01:09 AM
  #310
Devin86's Avatar
I doubt its E seems like 93 for those numbers. Idk tho is there a boost ramp mabe to save the tranny or anything u should hit 400's I feel??
Old 07-06-2015 | 04:13 AM
  #311
mh167002's Avatar
It is straight 93 octane. No Eathanol around here.
Old 07-07-2015 | 01:57 PM
  #312
user 72239's Avatar
Those seem like low numbers for that amount of boost
I was running 20 psi on 91 with low timing and made 359 whp 320 wtq on the 6758.
Old 07-07-2015 | 01:58 PM
  #313
KMO43's Avatar
On 24psi I found the 7163 as fast as my K04r at 28psi
Old 07-09-2015 | 05:59 PM
  #314
Typically mustang dyno reads 13% lower than a dynojet so 380 whp is 429whp on a dynojet which is not bad on 93 and 24psi. 6758 at 29psi on 93 can make nearly 450 whp I would say the 7163 at 29-30 could top that by around 30-40 whp.
Old 07-09-2015 | 10:05 PM
  #315
mh167002's Avatar
Good to know I'm not way off on power. Thanks Terminator2.
The next step is full exhaust and see how it does then. It runs pretty good, but I still have a catted downpipe and stock exhaust, so I should get some more power and reduce the lag a little bit I hope.
Old 07-10-2015 | 12:22 PM
  #316
hawkssoccer11's Avatar
oh man haha get those damn cats out of there and let the car breathe haha you will notice a huge difference then lol
Old 07-10-2015 | 09:49 PM
  #317
Midrange yes but on top end there should be no comparison the 7163 should kill it from 5500-redline.
Old 07-10-2015 | 11:01 PM
  #318
KMO43's Avatar
No 7163 at 23-24psi was the same as k04r at 28-29psi on my calibrated butt dyno
Old 07-11-2015 | 02:26 AM
  #319
KMO43's Avatar
I'm gonna try the vacuum canister delete tomorrow see how that helps my spool also am replacing a meth nozzle holder have to get ready for the dyno on Friday
Old 07-14-2015 | 04:56 PM
  #320
KMO43's Avatar
7163 dyno Friday 9am
Old 07-14-2015 | 06:24 PM
  #321
Devin86's Avatar
GL!
Old 07-14-2015 | 06:48 PM
  #322
KMO43's Avatar
Originally Posted by Devin86
GL!
Thanks! I'm hoping we both will hit our goals
Old 07-14-2015 | 06:50 PM
  #323
Whats your goal? I for sure want to see what that turbo can do
Old 07-14-2015 | 06:51 PM
  #324
KMO43's Avatar
I'll let that out if I hit it I don't want everyone to know how butt hurt I am if I don't make it!
Old 07-14-2015 | 07:04 PM
  #325
Lol fair enough
Quick Reply: 7163 zfr
