ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 07-17-2015 | 04:48 PM
  #376
nathan112i's Avatar
410whp*
Old 07-17-2015 | 05:26 PM
  #377
Originally Posted by KMO43
Thanks! 450whp was actually my goal
I kinda figured that was your goal. What kind of fuel where you running?
Old 07-17-2015 | 05:32 PM
  #378
KMO43's Avatar
My Dyno: 28psi 23* E25 550cc meth fully bolted
Nathan112i 27psi 15* 94 e0 1000cc meth fully bolted
KMO43 vs Nathan112i
Old 07-17-2015 | 05:46 PM
  #379
Idk much about dynos but it looks good man congrats
Old 07-17-2015 | 05:47 PM
  #380
KMO43's Avatar
Snail a dyno is a tool to measure the horsepower output of a car to the wheels.
Old 07-17-2015 | 06:18 PM
  #381
Lol i know what a dyno is, not so much how to read the graphs tho
Old 07-17-2015 | 06:23 PM
  #382
KMO43's Avatar
Posted some vids in here.
I was running E25 with 550cc meth
https://www.cobaltss.net/forums/dyno...4/#post7548011
Old 07-17-2015 | 07:15 PM
  #383
KMO43's Avatar
All dyno vids posted check them out
https://www.cobaltss.net/forums/dyno...4/#post7548036
Old 07-17-2015 | 09:09 PM
  #384
Told you itd make 500 on stock longblock :p
Old 07-17-2015 | 09:19 PM
  #385
KMO43's Avatar
Oh I know it can just not on my current setup
Old 07-24-2015 | 02:33 PM
  #386
Terminator2's Avatar
Originally Posted by nathan112i
410whp*
You need to get your meth hooked up so I can bring that thing up. Super conservative the way it sits
Old 07-24-2015 | 07:07 PM
  #387
nathan112i's Avatar
it is hooked up, running a 1000cc 60/40 there is alot left in it running 1000 but i don't need anymore power and 500cc wasnt quite enough.
Old 07-25-2015 | 12:49 PM
  #388
Send me over a log I can bump timing up and it will still be safe. By the way there is no way your boost and his are within 1lb just the extra timing is not worth 70 whp. I believe he has the high boost canister and you have the medium boost canister with makes a massive difference on the 6758 so it should on the 7163.
Old 07-25-2015 | 05:34 PM
  #389
KMO43's Avatar
I do not have the high boost canister on right now. I logged my pull and hit 28.0 psi I was on way better fuel so more timing and meth
Old 07-25-2015 | 05:50 PM
  #390
nathan112i's Avatar
i have no doubt that the car will take an extra 1-2* of timing with the amount of meth its spraying, i told kevin to stop adding timing because i was happy with the power.
Old 07-25-2015 | 09:59 PM
  #391
mongorat427's Avatar
Anyone run the 7163 on E 90 ? (10 gallons E 100 and 1 gallon 93) Im getting ready to try it out. I have 5th injector , fueling cam and Opel injectors. Installing a ZZP Stage 2 ported head at the same time. Car runs a lot better since I started mixing my own fuel.
Old 07-25-2015 | 10:06 PM
  #392
Sounds like your going to make alot of power. Cant wait to see the results
Old 07-25-2015 | 10:14 PM
  #393
Its time to get down and do it Ha Ha. Been spending to much time on the LS2 GTO
Old 07-25-2015 | 11:43 PM
  #394
KMO43's Avatar
I would run on e47 if I could so I had to buy c85
Old 07-26-2015 | 08:21 AM
  #395
I actually found a place in Ohio that sells pure E 100 . Rep told me to bring a couple extra gallon jugs. All the other places sell it with a additive that denatures it. I mix that 50/50 with Mountain Dew.
Old 07-26-2015 | 10:07 AM
  #396
You should try mixing it with Chuck Norris's **** (aka red bull)
Old 07-26-2015 | 12:46 PM
  #397
On a side note. I had a miss fire on cylinder # 4 for 6 months. Engine sounded a bit like a Subaru. Turned out to be a rocker came off and was laying in the head. Fixed that a car runs better than new. Had a few new spares sitting around so I changed the rocker and adjuster.
Old 07-26-2015 | 01:01 PM
  #398
Must be nice to have all those parts laying around lol
Old 07-26-2015 | 02:22 PM
  #399
KMO43's Avatar
I'm curious if I could get it shipped up here
Old 07-27-2015 | 09:08 AM
  #400
Santmyer Oil Company Ohio
