ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 08-15-2015 | 10:46 AM
  #476
SR Tech's Avatar
Gonna spray on an already 500hp stock bottom end? I would just order pistons and rods now lol.
Btw what are you lowered on?
Old 08-15-2015 | 11:11 AM
  #477
Lol he probably already has them
Old 08-15-2015 | 11:36 AM
  #478
KMO43's Avatar
I'd never spray on a stock bottom end. Eibach sportlines
Old 08-18-2015 | 01:45 PM
  #479
KMO43's Avatar
I'm booking dyno time first weekend in September
Old 08-18-2015 | 09:27 PM
  #480
Exciting!
Old 08-18-2015 | 09:30 PM
  #481
Nice lets see what she can do
Old 08-20-2015 | 08:11 PM
  #482
taintedred07's Avatar
Do you guys think the zfr 7163 with a ported head, stage 2 cams, opels, upgraded intank pump, 5th injector, e85, can reach 550whp at 30psi?
Do you guys think the stock turbo manifold is a slight hindrance?
Old 08-20-2015 | 08:45 PM
  #483
KMO43's Avatar
I do on a built engine but youll need more boost prob
Old 08-20-2015 | 09:07 PM
  #484
Hopefully not much more. I researched some online about extrude honing the stock manifold but most people say it's not worth it and expensive.
Old 08-20-2015 | 09:09 PM
  #485
You can port it yourself. Not sure how this would work on a 7163 car but i removed the divider on mine which is pretty thick so i imagine flow was increased at least a small amount.
If youre worried about the manifold you could get a t3 mani and use a t3 efr
Old 08-20-2015 | 09:15 PM
  #486
Trying to either remain cost efficient with the bolt on version, or pay way more for a kit like werks racing efr kit. Although I'm not sure if their stainless o2 housing is fitted for stock downpipe location.
Old 08-20-2015 | 09:26 PM
  #487
KMO43's Avatar
I believe that you hurt the flow taking that out! That divider will shield the next pulse from the previous and also direct the flow down towards the turbine. With taking out the divider all the exhaust energy will just crash into each other in the collector and not be nicely directed to the turbine
Old 08-20-2015 | 09:43 PM
  #488
And a friend mentioned removing the divider could make the casting more prone to cracking after periods of expansion.
Old 08-21-2015 | 06:54 AM
  #489
Goal was to spool slower and hold more boost up top.
Old 08-21-2015 | 09:45 AM
  #490
KMO43's Avatar
Those sre opposites spool slower mean less efficient and hold boost means more efficient.
Are you running a MBC?
Old 08-21-2015 | 11:33 AM
  #491
Spools slower because i got rid of the twin scroll, holds boost better up top because ported manifold(better flow in theory.) It was just something Al suggested to me so i went ahead and did it. And yes i have a hallman ES boost controller.
Old 08-21-2015 | 12:11 PM
  #492
KMO43's Avatar
Well a single scroll turbo will hold top end better but then again its designed to be a single scroll in the first place. I believe that divider straightens out the pulses and redirects them because its such a short manifold in the first place
Old 08-21-2015 | 12:41 PM
  #493
Too late now. Ill get a different set up eventually. Its just a k04..
Old 08-21-2015 | 12:43 PM
  #494
KMO43's Avatar
True. If you ever went 7163 I'd do what i did pick up a second set and port ceramic coat then install and you're golden
Old 08-21-2015 | 12:50 PM
  #495
Still undecided
Old 08-21-2015 | 01:06 PM
  #496
KMO43's Avatar
I'll have really good info very soon!!
Old 08-21-2015 | 01:41 PM
  #497
Lol i have a different engine tho
Old 08-21-2015 | 01:44 PM
  #498
Dipped_Cobalt's Avatar
tease
Old 08-21-2015 | 01:48 PM
  #499
KMO43's Avatar
Well ya but what are your goals?
Old 08-21-2015 | 01:49 PM
  #500
KMO43's Avatar
Originally Posted by Dipped_Cobalt
tease
Haha are you out of the loop? I've talked a lot about what I'm doing to finish the yeat
