7163 zfr
#76
Yes I think I can get it to 470 whp or so with the meth and same boost as it is running now just waiting on devil's own to send him a new fitting so we can start tuning it with the meth.
#78
Yep cams would add roughly another 15 whp or so to his car by themselves and will actually lower boost levels seen as the motor breathes better with them. Normally I see a 2 psi drop in boost with the cams so that allows me to make the wg ramp more aggressive while keeping sane boost levels.
#79
#80
So Term2 tuned a 7163 on a custome ZZP manifold but here's some info.
ZZP built a custom mani and they put the 7163 on it. Car ran great and spooled almost as fast as the 6758 but the top end flow was around 10-12 lbs/min higher than a 6758 at the same boost level. He sold the car not sure if the car's new owner is on here. The car has a 6 speed, cams, built motor, etc. I wish I had been able to tune the wg via HP tuners though the mbc took that control away and I do not like that.
#81
Its all in the tune, you should see the smooth progressive ramp on my setup, the initial hit is butter smooth and then ramps up a bit more at 4800rpms. But unfortunately once you've broken a tranny, you're always nervous about doing a 3rd gear pull lol. I know I am, I've been doing more 4th pulls on the freeway than any 3rd pulls anymore, its like i subconsciously baby 3rd gear. Another reason why I'm done modifying this car and going to step into the kappa platform with a 2jzgte swap.
#83
#85
We are still waiting on an exhaust housing from the foundry. They are way behind schedule. Once it is tested successfully, we will order a batch. It is a slow process.
#86
Thanks Matt that's awesome to hear an update. do you guys think the current .64 a/r housing is gonna work or are you going to a bigger one?
#87
#88
#90
#93
S259 is a much larger turbo than the 7163. 7163 compressor has a 57mm inducer and 71mm back side. By comparison, the 259 is 59mm and 80mm.
#94
#100
Unless I am miss reading this are you guys machining the 6758s housings to fit the 7163 internals? If so would you guys be offering this as an option? I only ask because I just purchased a 6758 and would interested in getting it machined to the 7163 prior to install. Again this is assuming I read the previous comments correctly before.
