ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 05-30-2014 | 11:59 AM
  #76
Terminator2's Avatar
Originally Posted by KMO43
So sounds like it is almost maxed think you can get that 20-30 extra hp with the meth?
Yes I think I can get it to 470 whp or so with the meth and same boost as it is running now just waiting on devil's own to send him a new fitting so we can start tuning it with the meth.
Old 05-30-2014 | 12:03 PM
  #77
KMO43's Avatar
that's sweet without cams and headwork
Old 05-30-2014 | 12:06 PM
  #78
Yep cams would add roughly another 15 whp or so to his car by themselves and will actually lower boost levels seen as the motor breathes better with them. Normally I see a 2 psi drop in boost with the cams so that allows me to make the wg ramp more aggressive while keeping sane boost levels.
Old 05-30-2014 | 12:09 PM
  #79
KMO43's Avatar
Then you'd be really close to what ZZP first made on the ZFR that would be great to see. I may have to get you to tune me when I finally get a turbo
Old 06-03-2014 | 03:54 PM
  #80
KMO43's Avatar
So Term2 tuned a 7163 on a custome ZZP manifold but here's some info.
ZZP built a custom mani and they put the 7163 on it. Car ran great and spooled almost as fast as the 6758 but the top end flow was around 10-12 lbs/min higher than a 6758 at the same boost level. He sold the car not sure if the car's new owner is on here. The car has a 6 speed, cams, built motor, etc. I wish I had been able to tune the wg via HP tuners though the mbc took that control away and I do not like that.
Old 06-05-2014 | 01:00 PM
  #81
08VRSS's Avatar
I'm running meth but right now I'm only looking to get around 475hp. I'm hoping since the 7163 is bigger it'll be nicer on the trans. I heard that the 7163 is a really smooth turbo
Its all in the tune, you should see the smooth progressive ramp on my setup, the initial hit is butter smooth and then ramps up a bit more at 4800rpms. But unfortunately once you've broken a tranny, you're always nervous about doing a 3rd gear pull lol. I know I am, I've been doing more 4th pulls on the freeway than any 3rd pulls anymore, its like i subconsciously baby 3rd gear. Another reason why I'm done modifying this car and going to step into the kappa platform with a 2jzgte swap.
Old 06-05-2014 | 01:07 PM
  #82
I looked back it was actually a 7064 EFR not a 7163.
Old 06-05-2014 | 05:26 PM
  #83
KMO43's Avatar
Ya would have thought so the 7163 is really hard to get your hands on It actually outflows the 7064
Old 08-05-2014 | 12:47 PM
  #84
KMO43's Avatar
So I heard that you could special order a 7163ZFR is this true? I'm curious to why no updates on this from ZZP I think they have onlt said one thing in this thread
Old 08-05-2014 | 01:37 PM
  #85
Matt M's Avatar
We are still waiting on an exhaust housing from the foundry. They are way behind schedule. Once it is tested successfully, we will order a batch. It is a slow process.
Old 08-05-2014 | 01:39 PM
  #86
KMO43's Avatar
Thanks Matt that's awesome to hear an update. do you guys think the current .64 a/r housing is gonna work or are you going to a bigger one?
Old 08-08-2014 | 04:02 PM
  #87
Matt M's Avatar
We have tested both. I like the .64 better for the LNF.
Old 08-08-2014 | 10:59 PM
  #88
KMO43's Avatar
Awesome I'm getting excited again too bad the season is basically done here in Canada but a fall or winter project for sure
Old 09-10-2014 | 10:15 AM
  #89
thatzthastuff's Avatar
Any updates on this?
Old 09-14-2014 | 01:08 AM
  #90
96S1's Avatar
In for updates.
Old 09-14-2014 | 01:19 AM
  #91
KMO43's Avatar
I can't wait either seeing what Infraredlines car does with his 259et which flows very close to the 7163 and on the .64 a/r it should have a good spool too!
Old 09-15-2014 | 04:20 AM
  #92
LNFwagonSS's Avatar
Subd
Old 09-15-2014 | 02:50 PM
  #93
Matt M's Avatar
S259 is a much larger turbo than the 7163. 7163 compressor has a 57mm inducer and 71mm back side. By comparison, the 259 is 59mm and 80mm.
Old 09-15-2014 | 02:55 PM
  #94
KMO43's Avatar
From the info I've seen online the 259et flows 62lbs/min and the 7163 flows 60lbs/min
Old 09-25-2014 | 12:52 PM
  #95
KMO43's Avatar
So what are the chances of the 7163ZFR being ready for Black Friday?
Old 09-26-2014 | 08:53 AM
  #96
taintedred07's Avatar
For 2015 or 2016?
Old 09-26-2014 | 11:25 AM
  #97
Matt M's Avatar
Possible.
Old 09-26-2014 | 12:08 PM
  #98
r3v07ut10n's Avatar
what kind of testing numbers did you get with the 0.64? ~470 on pump safe and within efficiency range?
Old 09-26-2014 | 01:38 PM
  #99
KMO43's Avatar
Possible.
Oh I have been waiting too long for this turbo to come out!!
Old 09-28-2014 | 03:44 AM
  #100
Waka Flocka Fluff's Avatar
Unless I am miss reading this are you guys machining the 6758s housings to fit the 7163 internals? If so would you guys be offering this as an option? I only ask because I just purchased a 6758 and would interested in getting it machined to the 7163 prior to install. Again this is assuming I read the previous comments correctly before.
