ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 11-10-2014 | 12:26 PM
  #126
slapbetcommissioner's Avatar
Originally Posted by Matt M
7163 has been approved for production and is in manufacturing right now. We will have them on the site in a couple weeks. I expect them to be shipping by mid December.
That's great news for all of those "patiently" waiting!
Any test numbers to tease us with?
Old 11-10-2014 | 12:48 PM
  #127
r3v07ut10n's Avatar
Biggest question will be stock issues. How many will they get at a time. I wonder what the demand of this turbo will be. I assume most people who have ZFR will want to upgrade. i know i do.
Old 11-10-2014 | 02:23 PM
  #128
LNFwagonSS's Avatar
I'm guessing the demand won't be as high as the ZFR 6758 was because of price and additional engine mods that may be needed to fully support the 7163. I know I will be getting the 7163 after a full engine build. I was pretty excited to hear about this turbo as I want my power to be in the 550 area with fast spool which seems doable with this turbo.
Old 11-10-2014 | 02:27 PM
  #129
user 72239's Avatar
oh man. this seems awesome. I would love to get mid 450's on pump gas.
Old 11-10-2014 | 04:01 PM
  #130
Yeah that sounds really good lets see the price tag once you get all the extra mods and stuff
Old 11-10-2014 | 05:29 PM
  #131
willdrew's Avatar
im in for this!
Old 11-10-2014 | 05:58 PM
  #132
Matt M's Avatar
7163 is worth about 30whp over the 6758 on setups running 25+ psi. It is a good choice for 25psi on pump gas or 27 psi on E85/E47.
Old 11-10-2014 | 07:46 PM
  #133
Im probably in too cant wait to see it
Old 11-10-2014 | 08:44 PM
  #134
KMO43's Avatar
YES!! Great news thanks Matt you made my day!!
Is that it? I thought it would be worth more but still I will be getting this ASAP!
Old 11-10-2014 | 10:07 PM
  #135
user 72239's Avatar
According to FullRace the EFR 6758 flows 53lbs/min and the EFR 7163 flows 60lbs/min.
So that would be a pretty decent estimate.
Old 11-10-2014 | 10:13 PM
  #136
Terminator2's Avatar
Max the 6758 does at 29psi is around 46lbs/min on stock cams. One I did with S1 cams is seeing 49lbs/min at 29 psi. If the 7163 can flow 5-6lbs/min over that real world at 29psi it should be good for around 40-50 whp over the 6758 at that boost level.
Old 11-10-2014 | 11:57 PM
  #137
KMO43's Avatar
Ya cause the max flow of the 6758 is 53 and the 7163 is 60 so anywhere from 5-7lbs/min more I'd guess 50hp over the 6758 will hit my goals tho!
Old 11-11-2014 | 11:39 AM
  #138
KMO43's Avatar
Hey Matt is it possible to buy this with the exhaust housing ceramic coated? I wanna get mine in black
Old 11-12-2014 | 12:35 PM
  #139
alerosaint's Avatar
Matt, Is this a good turbo to road course with ??
Old 11-13-2014 | 10:55 AM
  #140
Matt M's Avatar
I'm comparing a typical setup swapping to this turbo. The overall potential may be 50-60whp higher, but there are usually other limitations.
Old 11-13-2014 | 10:57 AM
  #141
Matt M's Avatar
I guess it depends how long the straightaways are.
Old 11-13-2014 | 05:57 PM
  #142
Knightwolf's Avatar
Lol.. looks like I have to upgrade my turbo with my engine build this winter :P Out by Black Friday or are we looking at December Matt? And what about pricing?
Also, this may not be relevant since I haven't relocated my MAF, but my scanner says I exceeded 53 lbs/min on the 6758.. If the MAF is relocated, it'll be significantly lower or what? That's what a local guy told me anyways, but then, he has to make up excuses that his turbo is better, even though he's nowhere even close to my current level... next year will be a whole new ball game And there's a lot of local guys supposedly building their **** this winter.. guess we'll soon see.
Screenshot for reference of lb/min on HpT scanner (This was quite a while ago and I believe one of my first few tunes with the ZFR) It's probably not accurate, but wth.. I'll let you guys flame away :P And yes I know the trims are out to lunch LoL I consider myself a novice tuner anyways, but I've had good results so far so I must be doing something right.
[IMG][/IMG]
Old 11-13-2014 | 06:04 PM
  #143
user 72239's Avatar
With trims that skewed, your MAF readings are going to be skewed too
Old 11-13-2014 | 06:10 PM
  #144
This. Retune your maf tables properly and the airflow readings will be more accurate. Also very cold dense air.
Old 11-13-2014 | 08:36 PM
  #145
AaronJ's Avatar
Lol in other words it would be a great turbo for Road America with its ridiculously long straights, but probably not the best choice for your local auto cross. The 6758 is about the biggest you'd want to go for autocross.
Old 11-18-2014 | 10:54 AM
  #146
alerosaint's Avatar
Thats what it sounds like. So a 6758 with an E tune probably do nice on long straights @ a safe psi(~20)
Old 11-18-2014 | 10:58 AM
  #147
Matt M's Avatar
We might decide to sell them on black Friday.
Your MAF frequency of 10,515 hz would correspond to ~38 lbs/min if you are using a ZZP lower charge tube and mounting the MAF there.
Old 11-18-2014 | 07:18 PM
  #148
raver0789's Avatar
Probably not a bad turbo if the lag is just a tad slower (as expected) than a 6758. Possibly 500whp and ~490tq on ethanol at 29psi. Beastly. Not enough airflow for me though
Old 11-18-2014 | 10:37 PM
  #149
Well just incase you guys didnt know zzp already has the turbo on sale for pre-order jist add 500 to the current zfr price
Old 11-19-2014 | 03:20 PM
  #150
Matt M's Avatar
I'm not sure if this has been talked about on here or not. The 7163 introduces a new aluminum center section housing. These turbos are extremely lightweight and also make a little more noise than the 6758.
