ZZ Performance ZZ Performance is a proud Supporting Vendor
7163 zfr
Old 12-19-2014 | 04:44 PM
  #201
raver0789's Avatar
This turbo interests me alot, i'm excited to see what it can do.
Ford, (username) ran up to 506whp full e85 on the s256et with just stage 1 cams, before running out of fuel.
Old 12-19-2014 | 05:57 PM
  #202
Terminator2's Avatar
Was he running 1.00 lambda at wide open?
Old 12-20-2014 | 01:17 PM
  #203
raver0789's Avatar
Funny. I didn't tune him, it was silverbullet08, taylor englund from hpunlimited. He's on hptuners all the time, i'm sure you know the name.
Knowing the fuel limitations of my own car on race gas, 506whp on e85 would have been absolutely impossible. But every car is different.
Seems like everyone forgot about his guy.
Old 12-20-2014 | 01:51 PM
  #204
Cobalt SS/TC dyno S256 - YouTube
Every car is different by a little but still 506whp on full E-85 and stock injectors is crazy. That is like saying you can make 600whp on race gas on stock injectors with just cams. I have done a ton of cars and not one would support that kind of power on E-85 with just cams not without leaning it out to the point of no enrichment happening in PE.
Old 12-20-2014 | 02:41 PM
  #205
raver0789's Avatar
I'm sure it had to have been leaned out as well. You can get away with murder on ethanol. I totally agree with what you are saying. On my setup with race gas, even it didn't like anything more than 0.86 lambda PE near 30 pounds of boost.
Old 12-20-2014 | 09:56 PM
  #206
billythakid's Avatar
Originally Posted by Matt M
We are including a note with the 7163 turbos that we ship, but I just want to post it here so more of you know. We are running the high pressure wastegate canisters on the 7163. We include medium pressure canisters on the 6758. This means that the duty cycle chart in the ECM must be adjusted differently with this turbo. To start out, I subtract 25% from the entire chart and set the max duty cycle to 75%. Be careful, because you can find yourself hitting 30psi boost in a hurry if you run a 6758 tune file with the 7163.
@matt so after the install can you still drive the car or do you need to tune it that day?
Old 12-21-2014 | 02:12 AM
  #207
nathan112i's Avatar
i can't hurt anything if you don't get into boost
Old 12-30-2014 | 12:41 AM
  #208
Ok so I just got my car back from gm all stock bring it back tomorrow but wanna see what yall think is the problem. Woke ok git in the car on interstate and at full boost 15psi is felt really slow like it was being held back thought let me try to reset the ecm got back on interstate pulled hard and ran fine next day did it again reset and it pulled hard again what do yall think is the problem thanks
Old 12-30-2014 | 08:18 AM
  #209
Scan for pending codes but MAP sensor is most likely the issue.
Old 12-30-2014 | 10:39 AM
  #210
It doesnt throw any codes. Someone was saying it could be the the purge solenoid but I just changed that 2 days ago they also thought it could have been a bad turbo (brand new turbo and motor) or leak didnt really agree thought id ask you
Old 12-30-2014 | 01:24 PM
  #211
Wert842's Avatar
15lbs on an all stock car and slow?
...There's nothing wrong with it.
Old 01-03-2015 | 12:16 AM
  #212
But why after I undo the battery and get back in theres a power qain and runs alot better also when it starts running funny it starts to boost higher at higher rpms for example it would spike 15 then creep up higher the rpms climb
Old 01-03-2015 | 12:37 AM
  #213
Wert842's Avatar
Aliens dude. All in the butt dyno. Would be awesome for a log or something.
Old 01-03-2015 | 02:39 PM
  #214
LNFwagonSS's Avatar
It's not uncommon to see a small power gain or boost gain after pulling the battery or resetting the ECM. Quit resetting the ECM and let it learn the parameters then do your diagnostics.
Old 01-03-2015 | 09:32 PM
  #215
Aliens dude. All in the butt dyno would be awesome for a log or something.
Aliens
Old 01-03-2015 | 11:45 PM
  #216
nathan112i's Avatar
Old 01-08-2015 | 08:18 PM
  #217
raver0789's Avatar
Anyone logged any of these bad boys yet? How did it go? It's too cold up here I'm going to have to wait for spring to see one.
Old 01-08-2015 | 08:22 PM
  #218
Wert842's Avatar
I don't think anyone actually got their hands on one.
Old 01-14-2015 | 11:45 AM
  #219
Matt M's Avatar
We shipped 6 or 7 of them mid December.
Old 01-15-2015 | 11:07 AM
  #220
raver0789's Avatar
Yup. A guy up here has one. But it's winter. We won't see him on our dyno until April.
Old 01-16-2015 | 10:46 PM
  #221
SpeedyGirl07's Avatar
When are these coming back in stock?!?! I'm ready to order one
Old 01-24-2015 | 12:48 AM
  #222
Installed my 7163 last Sunday and finishing the tuning tomorrow
Old 01-24-2015 | 12:52 PM
  #223
Wert842's Avatar
keep us posted. Any info on spool time and have anything to compare it to?
Old 01-27-2015 | 01:51 PM
  #224
James was saying it spools very similar to the 6758. Had to ramp it.
And is good for 35psi im only on 26/27 pounds on 93 doing a 3.8 from 60-100 I posted it on cobalt ss gangs facebook page
Old 01-27-2015 | 03:06 PM
  #225
KMO43's Avatar
Wow I thought it would spool around 3500 that sucks I don't believe in boost ramps
Quick Reply: 7163 zfr
