ZZ Performance ZZ Performance is a proud Supporting Vendor
Any interest in a group buy on mid length header downpipe combos?
Old 12-23-2007, 07:38 PM
  #1301
XbandiniX's Avatar
Well... threw a code today... P0420 catalyst effiencieny below threshold.. Anyone else get this after the install? i haven't been driving crazy so i dunno whats up.. Anyone have input???
Old 12-23-2007, 08:02 PM
  #1302
06_SS_S/C's Avatar
I got that too the first day I fired it up but I cleared it and hasn't come back since. Maybe just because of the change? I dunno.
Old 12-23-2007, 08:11 PM
  #1303
Super_SS's Avatar
Originally Posted by 06_SS_S/C
Did that exhaust leak ever get fixed with a larger gasket? I think mine is leaking too at the same spot. I was getting on it today and sounded like a leak right under the shifter...
the performance shop i go to is closed,and will open monday,so im goin in the morning to buy a thicker gasket and will see if it helps..mine is barely noticed at idle,but when u get on it,u can hear a "air whistle" right under the shifter(header/downpipe connector..i will keep u informed
never had it come on..drove the car 2 days and never came on,and found someone local with hp tuners and had them delete that code and the lean intake code,as well as trq managment
Old 12-23-2007, 09:28 PM
  #1304
D4u2s0t's Avatar
your o2 sensor is programmed for the stock air flow, and now that it's seeing more air it's triggering the code. the car doesn't know that you put on a new header/dp w/a high flow. it just knows it's seeing more air. if there's no leaks or anything just delete the code.
Old 12-23-2007, 10:26 PM
  #1305
stealthy1ss's Avatar
It is cold enough in chicago to tell if you have a leak. You will hear the exhaust flowing more now because of there being more area for it to flow in. If you can't see any exhaust coming out from under the car then your gaskets are fine.
Originally Posted by freakta
ok thanks for the input
If your box was damaged and that dent happened because of shipping and you signed for it then you are out of luck. The reason why is because ZZP sent you a perfectly good header and it is UPS that made that mistake and you shouldn't have signed for it.
Old 12-23-2007, 11:04 PM
  #1306
XbandiniX's Avatar
ok kool thx guys.. i cleared the code and hopefully it don't come back..
Old 12-23-2007, 11:46 PM
  #1307
elecblue06's Avatar
do one consensus with everything is zzp needs to package things better it seems
i have to say paper in a thin makeshift box sucks... some bubble wrap would help out and a cardboard divider between the header/ dp would be lovely
Old 12-24-2007, 01:49 AM
  #1308
06_SS_S/C's Avatar
Oh and FYI, I climbed back under the car today and I know when I first installed it I tightened down those bolts between the header and DP as tight as I could get. When I got under there today, I was able to tighten them up probably another full 2-3 turns each and that got rid of the leak sound I was getting.
I don't know if the gasket shrinks/seals after it gets warmed up, but I would definitely check those bolts again and just make sure that they are as tight as possible.
Old 12-24-2007, 01:52 AM
  #1309
D4u2s0t's Avatar
that's pretty normal with any install. should always check the bolts after some driving.
Old 12-24-2007, 08:21 AM
  #1310
Bannned
ColeJJones's Avatar
after the install did you guys smell anything when you were driving? or is that just the new stuff on the pipes buring off. i dont have it anymore but i did
Old 12-24-2007, 08:57 AM
  #1311
sick06cobalt's Avatar
its just the pipes getting warmed up and breaking in.. its normal... Hey I heard someone talking about clearing a code.... will that happen on a 2.2?
Old 12-24-2007, 09:22 AM
  #1312
D4u2s0t's Avatar
oils from the bends, hands, etc. it's normal. should go away after a while.
Old 12-24-2007, 02:14 PM
  #1313
elecblue06's Avatar
any more sound clips to be posted?
Old 12-24-2007, 06:14 PM
  #1314
an0malous's Avatar
ITS HERE!!!!!!!!!!!
yayyyyyyy
packaging was less than stellar, though thankfully both parts are in very good shape.
no dings or scratching.
duties were only $36 woohoo. very happy about that.
Old 12-24-2007, 09:54 PM
  #1315
Bannned
ColeJJones's Avatar
awesome!!! cant wait until you guys put them on. im excited cause it sounds so beautiful
Old 12-24-2007, 10:33 PM
  #1316
RollOver360's Avatar
Too bad i gotta wait until i get EVERYTHING else that im gonna put on this winter. Just waiting on injectors, nitrous, and meth inj. Plus my poor cobalt is sitting in the garage... so lonely
later
Old 12-25-2007, 10:08 AM
  #1317
XbandiniX's Avatar
God dammit!!! the CEL came back.. any ideas anyone?? i cleared the code twice and dissconnected my battery and it came back again.. Could somthing be loose?
Old 12-25-2007, 10:53 AM
  #1318
Bannned
ColeJJones's Avatar
i got a cel but only cause i left my sensor off and just left the hole open for a lil bit. but i put it back and after about 15 miles it went off....either im lucky or there is something wrong with your ****
Old 12-25-2007, 11:00 AM
  #1319
elecblue06's Avatar
maybe a leak? merry christmas
Old 12-25-2007, 11:04 AM
  #1320
Bannned
ColeJJones's Avatar
yea, i would say a leak... maybe... double check your stuff man
Old 12-25-2007, 11:30 AM
  #1321
It probably is not a leak cause the sensor is just sensing more air passing then normal. You will need to have someone take care of it with HPTuners.
Old 12-25-2007, 01:13 PM
  #1322
freakta's Avatar
ya too bad there was no damage to the box and i didnt sign anything but its cool that you said it
Old 12-26-2007, 06:34 PM
  #1323
brownbandit9's Avatar
mine still sais in process on the zzp site...hasnt shipped yet...is this the case for you other guys aswell..i was only 14 on the list..i understand if they hadnt made them yet..but havnt they already been made
Old 12-26-2007, 06:35 PM
  #1324
DoubleLP's Avatar
did you pay the extra to have it shipped earlier? If not......then you have to wait for them to ship them.....which should be shortly since they have more then 25 people in the GB now.
Old 12-26-2007, 07:07 PM
  #1325
elecblue06's Avatar
any more sound clips? i unfortunately still dont have it on
Quick Reply: Any interest in a group buy on mid length header downpipe combos?
