Any interest in a group buy on mid length header downpipe combos?
#1376
My header and downpipe are INSTALLED!!!!
And just like an0molous....I get a deeper tone and the hesitation out of first is GONE.
Thank you ZZP.......this is an awesome product and I would recommend it too anyone!!
#1379
Yes....yes I did. Thank you Midas on MacLeod!! $200 to install it, plus I needed a new rear O2 sensor ($300.....thanks GM) because the threads on the other one were screwed and would have ended up screwing up my new threads on the downpipe. The could not be filed or fixed in anyway. I watched the guy do the whole thing and take the sensor out and show me. It was really stuck and took a lot of time and WD-40 to get it to come out.
#1381
Yeah true.....but it is done now and in place. I do have the extra O2 bung for my Wideband which I just picked up from Spaz. So that will hopefully be in soon and then up next is lowering springs and a tune.
#1382
#1383
I think i already asked this but for the people who installed their headers, did yous put your stock heat sheild back on after? will this hurt anything if not put back on?
#1385
You can't put the heat shield back on because it won't fit on the new header. And nothing should be anywhere NEAR the new header to be melting.
#1386
#1388
Hey is anyones kinda banging on the heat shield or anything under the car? just wondering because mine is... so any help would be great.. it may not just be banging there but anywhere else...
#1389
i bent and beat the the hell out of mine and it would fit... but i ended throwing it away cause i like lookin at my header when i want
https://www.cobaltss.net/forums/problems-service-maintenance-69/zzp-header-dp-corsa-exhaust-problem-89202/
#1392
i threw my heatshield away...
read please
https://www.cobaltss.net/forums/showthread.php?t=89202
read please
#1393
I would keep that one in place, otherwise you might get a lot more heat in your car in the summer.
You should be able to just bend it out of the way easily.
#1394
#1395
okay so something is rattleing... its coming either from something under the car or my tranny lol.. i think its the heatshield under the car i cant figure it out.. i bent everything out... so i dont know what it is... could this be a leak... it is really loud inside the car when i get on it... could i have killed the cat? I mean someone please help me.. ill get a video of it tommorow...
#1396
#1399
get under the car, and have someone start it JUST FOR A SECOND OR TWO. it will help you pinpoint the location of the rattles. I had some crazy ass rattles too, turned out to be the harness for the rear 02 sensor banging against the tranny mount.
#1400
hmm.... its wierd because my shifter will move too.. like its right around the tranny area.... but ill have to look for it because its really pissing me off... and i want it fixed.. if it is the cat for some strange reason what should i do? go to a local shop and order a new one? and then weld that one on?
