ZZ Performance ZZ Performance is a proud Supporting Vendor
Any interest in a group buy on mid length header downpipe combos?
Old 01-02-2008, 08:12 PM
  #1376
DoubleLP's Avatar
My header and downpipe are INSTALLED!!!!
And just like an0molous....I get a deeper tone and the hesitation out of first is GONE.
Thank you ZZP.......this is an awesome product and I would recommend it too anyone!!
Old 01-03-2008, 11:11 AM
  #1377
freakta's Avatar
Originally Posted by gumbyflav
must be nice to have them in. I gotta wait till my mess gets situated....................aagggghhh(fustrated).
i know what you mean zzp should be getting my header back today...
Old 01-03-2008, 12:24 PM
  #1378
Banzai2.4's Avatar
damn mike, u got it installed already??
Old 01-03-2008, 02:46 PM
  #1379
DoubleLP's Avatar
Yes....yes I did. Thank you Midas on MacLeod!! $200 to install it, plus I needed a new rear O2 sensor ($300.....thanks GM) because the threads on the other one were screwed and would have ended up screwing up my new threads on the downpipe. The could not be filed or fixed in anyway. I watched the guy do the whole thing and take the sensor out and show me. It was really stuck and took a lot of time and WD-40 to get it to come out.
Old 01-03-2008, 02:53 PM
  #1380
an0malous's Avatar
woulda been cheaper to just plug the hole or put a wideband in it. and disable the rear O2
its only there to test your cat efficiency anyway hehe.
Old 01-03-2008, 06:37 PM
  #1381
DoubleLP's Avatar
Yeah true.....but it is done now and in place. I do have the extra O2 bung for my Wideband which I just picked up from Spaz. So that will hopefully be in soon and then up next is lowering springs and a tune.
Old 01-03-2008, 06:39 PM
  #1382
anthonyS88's Avatar
same **** happened to me,my rear o2 sensor was stripped when i took it off
Old 01-05-2008, 02:32 PM
  #1383
XbandiniX's Avatar
I think i already asked this but for the people who installed their headers, did yous put your stock heat sheild back on after? will this hurt anything if not put back on?
Old 01-05-2008, 03:02 PM
  #1384
pjk91's Avatar
I didn't put mine back on either. Weight reduction ftw! Hopefully I'm not melting anything away. I'll check it out Mondaywhen I get it on the lift.
Old 01-05-2008, 03:17 PM
  #1385
DoubleLP's Avatar
You can't put the heat shield back on because it won't fit on the new header. And nothing should be anywhere NEAR the new header to be melting.
Old 01-05-2008, 05:47 PM
  #1386
XbandiniX's Avatar
It is possible to put it back on.. all you have to do is bend it. I was just wondering if it was necessary.
Old 01-05-2008, 06:37 PM
  #1387
DoubleLP's Avatar
I don't see why you would need it.....there is lots of space.
Old 01-05-2008, 07:55 PM
  #1388
sick06cobalt's Avatar
Hey is anyones kinda banging on the heat shield or anything under the car? just wondering because mine is... so any help would be great.. it may not just be banging there but anywhere else...
Old 01-06-2008, 04:36 AM
  #1389
Bannned
ColeJJones's Avatar
i threw my heatshield away...
i bent and beat the the hell out of mine and it would fit... but i ended throwing it away cause i like lookin at my header when i want
read please
https://www.cobaltss.net/forums/problems-service-maintenance-69/zzp-header-dp-corsa-exhaust-problem-89202/
Old 01-06-2008, 08:00 AM
  #1390
DoubleLP's Avatar
X 2!!!!!!!!!!!
Old 01-06-2008, 11:00 AM
  #1391
Im not talking about the heatshield off the engine block.... thats not what it is... lol.... its comeing from under the car at idle sometimes or it bangs....
Old 01-06-2008, 11:12 AM
  #1392
anthonyS88's Avatar
read please
https://www.cobaltss.net/forums/showthread.php?t=89202
what does that have to do with the rear o2 sensor being stripped?
Old 01-06-2008, 12:19 PM
  #1393
DoubleLP's Avatar
I would keep that one in place, otherwise you might get a lot more heat in your car in the summer.
You should be able to just bend it out of the way easily.
Old 01-07-2008, 01:13 AM
  #1394
Bannned
ColeJJones's Avatar
well, if you read....!!!! you will see that i had the same problem but i fixed it!!!
Old 01-12-2008, 11:44 PM
  #1395
okay so something is rattleing... its coming either from something under the car or my tranny lol.. i think its the heatshield under the car i cant figure it out.. i bent everything out... so i dont know what it is... could this be a leak... it is really loud inside the car when i get on it... could i have killed the cat? I mean someone please help me.. ill get a video of it tommorow...
Old 01-12-2008, 11:50 PM
  #1396
stealthy1ss's Avatar
Did you break in the cat properly by not getting on it for around 500 miles?
Old 01-12-2008, 11:51 PM
  #1397
for the most part yeah,...
Old 01-13-2008, 01:38 AM
  #1398
elecblue06's Avatar
that for the most part might be your problem... it seems some of magnaflows stuff has been taking a **** dive quality wise... but i dduno man
Old 01-13-2008, 09:21 AM
  #1399
D4u2s0t's Avatar
get under the car, and have someone start it JUST FOR A SECOND OR TWO. it will help you pinpoint the location of the rattles. I had some crazy ass rattles too, turned out to be the harness for the rear 02 sensor banging against the tranny mount.
Old 01-13-2008, 09:25 AM
  #1400
hmm.... its wierd because my shifter will move too.. like its right around the tranny area.... but ill have to look for it because its really pissing me off... and i want it fixed.. if it is the cat for some strange reason what should i do? go to a local shop and order a new one? and then weld that one on?
Quick Reply: Any interest in a group buy on mid length header downpipe combos?
