ZZ Performance ZZ Performance is a proud Supporting Vendor
Any interest in a group buy on mid length header downpipe combos?
Old 11-26-2007 | 12:29 AM
  #201
sick06cobalt's Avatar
Did you get my pm...? I get paid about 200 bucks a week so this shouldnt be too bad...
Old 11-26-2007 | 12:30 AM
  #202
stealthy1ss's Avatar
Yep thanks.
Old 11-26-2007 | 02:47 AM
  #203
SS/SCking's Avatar
1.5'',mild, painted, catless, 3'' outlet.....259$? +an extra bung?
Old 11-26-2007 | 04:29 AM
  #204
Super_SS's Avatar
for the noob's that dont understand the zzp exhaust crap plz explain to me(im a nooby)
Model:
1.5" Paint(so im guessin this is how thick the coating will be over the header so it keeps the heat inside)
Option 2:
I understand this section.Im gettin the Magnaflow high flow cat since i dont want a loud farting and annoying sound.
Option 3:
Whats the best size for a downpipe so i dont go overboard...i knw turbo's like it bigger the better,but not to much..3" is the best..Im guessin 2.5 bolt in(can bolt into stock or aftermarket 2.5" piping)
So 419-30%=293.30+bung for wideband
Old 11-26-2007 | 10:07 AM
  #205
07 SS/SC's Avatar
I cant believe I just saw this now!
Ooooo this makes me want to buy stuff.
Old 11-26-2007 | 10:11 AM
  #206
Z Speed's Avatar
is there any resolution to the problem with the gasket blowing out for the downpipe..... my brother has this setup and snapped the bolts in a few weeks then replaced them with the gasket and now keeps blowing gaskets out..... we have used air tools to tighten everything and keeps happening. I think its cause its a 2 bolt setup allowing to much flex causing them to blow from engine movement
Old 11-26-2007 | 10:46 AM
  #207
gumbyflav's Avatar
Wow, this is a great offer. 30% off (if everyone is stays in), none the less, a great buy. .......
Q.1/ What is a good combo for a SLP Loudmouth II?. I'm deployed and cannot messure the exhaust pipe.
Old 11-26-2007 | 11:07 AM
  #208
elecblue06's Avatar
they upgraded the bolt so it should be all set
Old 11-26-2007 | 11:48 AM
  #209
68nova200's Avatar
how much would shipping be to northern NJ?
Old 11-26-2007 | 11:54 AM
  #210
elecblue06's Avatar
probably 25 bux for UPS ground
Old 11-26-2007 | 12:08 PM
  #211
68nova200's Avatar
how are they going to take the orders?
Old 11-26-2007 | 12:13 PM
  #212
elecblue06's Avatar
after dec 1st i'm guessing they'll give a discount code for their site or something
Old 11-26-2007 | 12:16 PM
  #213
68nova200's Avatar
should i register for the site now or later?
Old 11-26-2007 | 01:00 PM
  #214
an0malous's Avatar
Model:
Option 2:
Option 3:
the measurement in option one is the size of the primary piping in the header. (the 4 pipes coming from each cylinder.
the 1 3/4 pipe would probably be best left to the modded ss/scs, 1 1/2 should be good for everyone else unless you know your turboing or something.
paint or ceramic is self explanitory. ceramic is an expensive coating process which holds the heat inside to keep the gasses in the header expanded and flowing fast away from the heads.
downpipes: 3 inch once again, more for the ss/scs.
your exit type will depend on what catback you have/want.
weldin: comes with no bolt up flange,
2.5 inch boltin: this is what most people will want. stock and all the gmpp exhausts all use 2.5 bolt in flanges.
Old 11-26-2007 | 01:22 PM
  #215
gumbyflav's Avatar
HELP>>>>Is it safe to assume 2.5 exit will match up the SLP Loudmouth II?
Old 11-26-2007 | 01:26 PM
  #216
an0malous's Avatar
yes.
http://www.lmperformance.com/16463/78.html
its a 2.5 inch exhaust.
google is your friend.
Old 11-26-2007 | 02:38 PM
  #217
Zooomer posted early in this thread that everything has been updated including bolts.
Old 11-26-2007 | 03:55 PM
  #218
Banzai2.4's Avatar
Bump!!
Old 11-26-2007 | 06:04 PM
  #219
This is looking good guys. I am only waiting for 6 more people to pm me back.
Old 11-26-2007 | 06:12 PM
  #220
elecblue06's Avatar
how many we got confirmed so far?
Old 11-26-2007 | 07:35 PM
  #221
hubes's Avatar
Im possibly interested, just have a few questions.
1. when you say gaskets included, do you mean all 3?
2. what guage tubing do you use?
3. would it be possible to get a 2.5" dp that tapers to 2.25" for a smooth transition to my gmpp cat back?
4. do you ship to canada?
Old 11-26-2007 | 07:38 PM
  #222
an0malous's Avatar
i can help with that a little
1. "Header and both downpipe gaskets included" (quoted from www.zzperformance.com)
2. that I dont know
3. the 2.5 inch flange bolts up to the gmpp catback. dont need 2.25
4. yes. (if you go to zzperformance.com and pick which header you want, and go to checkout you can see the shipping options and prices)
Old 11-26-2007 | 08:49 PM
  #223
pjk91's Avatar
Am I still going to pass emissions if I don't get a cat on the DP?
Old 11-26-2007 | 08:50 PM
  #224
D4u2s0t's Avatar
no you won't pass.
Old 11-26-2007 | 08:54 PM
  #225
camarokiller's Avatar
1. elecblue06
2. Banzai2.4
3. flathead0
4. dvsk8er
5. rockstarbass1
6. quadracer0387
7. 06_ss_s/c ?
8. RollOver360
9. brownbandit9
10. An0malous
11. Altiery54 ?
12. rob561?
13. Infernokron ?
14. gumbyflav
15. EcotecRacer?
16. freakta
17. stealthy1ss
18. lewisb13
19. mcwarren
20. OBZ
21. D4
22. Super_SS
23. dtabbs
24. Sick06cobalt
25. 68nova200
26. pjk91
27. camarokiller
