brfps w/ fuel lab regulator
So I ordered this kit from you guys and honestly am not sure how to hook it up...I tried looking on your site and calling to get some help and nothing so far. Guess we will see if this works :S I have tried hooking it up different ways for a few hrs and end up just being back to square one!
HELP PLEASE! I wanna get this hooked up so i can get tuned and fianlly drive my car again... Thanks!
Connect all your lines as shown. Once you have done this, you can use this fixed position as a reference for mounting the regulator. Drill and mount the bracket to the car.
If you did not order the evap fittings and used steel line instead, then connect it the same as if you were using the evap line. Instead of attaching the push connect fittings you will be attaching the rubber hose to the steel line.
